Saginaw install problem
Columbia, SC
Has anyone had the same problem installing a saginaw conv. with the Proffitts Cruisers shackle reversal hanger?
I welded up my Proffitts hanger last night and I had already checked where my steering box plate needed to be welded on at so I welded it on after that. With my holes cut in the cross member for the shaft and everything welded up, I went to bolt my steering box on and the round lip on the end of the box hits the edge of my hanger. :doh:
I am using the AGR box, and I know it is a little larger diameter, could this be the problem. :idea: Should I notch out the box, the hanger, or take off the hanger and drop them down about an inch? Or should I put more spacers between the plate to kick it out about another 1/2 inch? I am using Posers bracket so all the spacers were pre measured and welded on.
I will post some pics when I get home tonight. Thanks for any help guys.
Besides this, yesterday was a very productive day. I made my rear shackles and mounted my 55 springs, put my rear disk brakes on, and started on the front SOA,SR,PS conv. Everything on the front is off and all I have to do is put all the new stuff on.
Can you notch & rebrace the hanger some? Have you test fit the bumper yet? I had to notch mine on the top. I would not add spacers as there's a lot of stress on the steering box bolts & I hope you're using grade 8.......
Here is a pic...
Thanks LC and Hawk.
I will try to do some notching tonight. Is it ok to notch that lip around the end of the box?
I WOULD NOT notch the box....not to make that gear fit that gap....
I have not ever used these mounting plates with a shackle hanger like those...
I would cut the plate off and move the gear forward, or figure out how to move the plate inboard to let the gear miss the hanger...I would not use longer spacers, as the increased leverage on the mounting points and hardwear could lead to the box being ripped out from the mounting plate. I would also look at using a steering box brace to support the gear to the other side of the frame. There have been a few threads out here on this topic, with pictures.
Good luck!
-Steve
Thanks Poser. The plate is already welded on, really welded on.
I got the box and plate lined up perfectly and then welded it on, the hanger went on after that. I made sure the box was at the right location to clear the cross member and have the right angle for my steering shaft. I didn't think about the hanger getting in the way.
Maybe a 1/2" plate between the hanger and the frame will give me some extra room to work with. I can get the hanger off, the steering plate will never come off.
Thanks for all the help.
Jeremy
Move the plate..
Bad idea to space things.. Unless you really do want to be on the side of the trail with a steering box off of the frame..
It really does pay to do it right the first time. Redoing things out on the trail sucks. I have a LOT of experience in that area..
The only way to move the plate that would have fixed this was to move it up.
This would put my box level with frame and not at any angle for the steering shaft. The box can not go any closer into the crossmember and pulling it out of the cross member would mean having to use a spud shaft extention.
Jeremy
I realize I'm bucking an experienced tide here - shoot me down if I need it - but the box is already bolted to spacers. (So is mine.) It looks like another 1/4" will get you away from the frame far enough to clear the hanger. If so, why not replace the existing spacers with with ones that are 1/4" longer? You could even make them a little larger diameter to add stability.
I am thinking the same thing as theo, but then again, I have never had to rig my ps box onto my rig while out on the trail.
I know this isnt a solution youre going to go for, but I will throw it out anyway- you could bail on the AGR and go with a standard 4 turn box- which will probably clear.
Another option is to grind down the spacers on that mount, and weld another ps plate ontop of it.
I am running those hangers, but have Butch Lewis's ps plate (like 4x4 labs has) which places the box horizontal on the frame, instead of at an angle- and my pump clears the hanger.
-Dustin
There is nothing wrong with having the box level.. That is what the U joint is for..
your set up is identical to mine. I added a 3/16 plate to inside of frame and my box lip just touches it at front. So , looking at you pics I would say just gring the welded on steering box plate right in the front to clear lip of box and move spring hanger outboard 1/4 inch. Actually , now that I think about it the stock LC hangers That I moved up front for SR have a 3/4 " 45 * bend right at that corner of the hanger where jeremiah's are 90 * , thats whats @&@&@&@&in ya right there.
Thanks, peesalot.
Should I just mount my bumper and move the hanger forward even more to underneath the bumper? It is made out of 3.5" x 3.5" square pipe and capped. I will weld it and bolt it to the frame.
Is that going to put my axle to far forward or is that better? I don't know what that would do to my drag link in relation to where my box is mounted now.
Jeremy
Moving the mount forward is an excellent idea.
More WB is better ;)
Thanks Mace. I will move the hanger to the bumper. With the springs flipped and depending on where the hanger ends up I should get about 5" to 6" in the front. My rear 55's gave me about 3.5", so I should be close to a 100" wheel base. I will get to work tonight. Will post when fixed.
Thanks for all the ideas guys.
Jeremy
