Rust experts advise needed
Is this rust repairable?
I put my 68 FJ40 on it's side fall or 1975. Started repairing it until I found a perfect top from a 73 for cheap. It was damaged closer to the front by the B pillar. The mustard hard tops sides were given to my many years ago and believe of a 79. Is it worth repairing the rust using a piece off my 68 top? Thought about making a sleeve for the square section. To align and stiffen that are. To show why people are always want AZ cruisers, these sides pieces have been stored outside uncovered for over eleven years. This is the other one. The top side shown was resting directly on concrete.
Wasn't planning on using these sides but my 79 currently has a 77 top on it which has seat belt brackets I have no use for on my 79. Thought these both were both rusted in a couple places but just the back rear of the passenger's side has rust. But just the one area.
John, I think it would be repairable if you had a good donor section. I have some passenger hardtop sides and will check if I have anything you can use.
Thanks Tim, I have a good donor already. My 68 which is rust free I laid on the passenger's side ago years. Started repairs which weren't going well when I found a perfect 73 top. That was back in 75. The back section wasn't damaged. The side window broke but corner window was find. To get a good 78+ top have other side panels which don't have damage but could cut up. One I date 1/75-12/75 and it's mustard. But other than a few drill holes it's in good shape. Held on to my 68 damage panel this long may as well use it.
It is repairable if you have the tools and are pretty familiar with welding thinner sheet metal. If you do it will be fairly straightforward especially if you have a donor section to use once you cut the rot out. That will save you hours and hours of fab time and will look much better. I suggest removing all the glass/weatherstripping and getting it media blasted for starters. From the pics the rest looks good, but media blasting will certainly tell you for sure.
Take plenty of pics. We all love seeing repairs like this on the site.
I’ve made that same repair on a couple hardtop panels. No patch panels needed. It can all be bent in a vice or a small brake.
Agree it could be made but why when I've spent years building a personal salvage yard. Noticed I have a early soft top that has a 1/75-12/75 hard top on it. This top is actually damage worse than my 68 top. But is good in the area I need so why make something I already have. Not a welder so would make the replace than have someone else weld it or give it a shot with silver solder. My hood had a slice from what believe was a exploding fan. Straightened it and silver solder the slice. That was back in the early nineties and can't tell it was repaired from either side. When I put my 68 on it's side the front fender roller under a little. Noticed it now has a small stress crack where the brace underneath ends. When I have it paint again I will repair the crack with silver. For my patch going see if I can cut the box section longer then work the extra down to slip inside the main panel. Get both sides down to bare metal using flux and heating it right could get the two pieces soldered together which would really make a stiff patch.
I’m just going to spectate this one for tips and pictures - your sides look like mine. @Splangy ‘s comment was encouraging! I don’t have a set of donors but if you don’t mind posting pictures as things progress I’d be interested to see how they all fit together.
Good luck with the repair and I would like to see the progress pics as well. If you're successful, it will give hope to every cruiser North of Illinois.........:cheers:
I like how all the rust experts live in the northeast!!!!!!
