Rumble Pig
Ferndale, WA
My kid decided, when he was 5, that my 1990 F250 with the 7.3l IDI was the "Rumble Truck". Now that I have a diesel 55, he has decided that it is the "Rumble Pig" (he is now 8). Works for me :)
In case anyone was wondering where Tucker's '79 55 went, wonder no more. It is now at its new home, in the PNW, in my shop where it is getting some lovin'.
The truck is very straight with relatively little rust, and Tucker did a great job with the build components he tackled. I have been focusing on the engine bay, as the owner before Tucker apparently did not like wiring, so seems to have spent as little time as possible on it. I've been tidying up the engine bay, and there was also a coolant leak to attend to. Ended up being the gasket between the water pump housing and the block, as well
as 2" chunk of hose known as the "bypass hose". The MBZ OM617 motor is pretty easy to work on, and there is a ton of info out there that has been very helpful.
Plans at this point are to get the cooling system back together, finish soldering new wire terminals and get all the wiring plugged back in, install the new glow plugs, and then drive, drive, drive.
Will of course be doing rust repair/remediation, and a paint job is in this lil' piggy's future. Going to put it back to blue and white (original color scheme) though probably not smurf blue.
The '76 55 I originally bought will be up for sale soon, and the other '76 and " 77" I've got I will continue to part out.
Looking forward to daily driving this pig, and seeing how it does in the snow and the wet and sloppy trails we have in the PNW!
Kinda figured folks had seen this rig already :meh:
Piggy by Tucker Thurman
https://forum.ih8mud.com/threads/fresh-pork.625020/z
I am remiss, however, in not taking pics of the crazy Russian transport driver, whom was three days late delivering and whose truck broke down on the side of the freeway requiring I drive a few hours south of home to get my piggy.
That said, I did get the chance to drive the 55 about three hours home, and for anyone on the fence about power steering, DO IT! My '76 has Armstrong steering, and the power is so much more enjoyable and practical. Also, if anyone is considering a 5-speed tranny, I would def recommend that too. Ride on the truck (just pavement so far) felt great, and the ride height is def improved over stock IMO.
And @Delancy if you want any pics of the removed radiator, crusty thermostat housing, or crumbly water pump gasket, just let me know:p
did you lay paint down before fixing that hole? You've got to stop taking advice from me...
Kinda figured folks had seen this rig already.
I've seen a pic of Kate Moss before, too....
I am remiss, however, in not taking pics of the crazy Russian transport driver...
Best I can figure, the remnants of the KGB that the SVR didn't take.
Have met a couple of scary looking dudes that, if the vodka fumes didn't kill, their look would.
no one can pronounce Mercedes Benz like a ex gulag freight driver
oh gawd I know, I know...LOLit looks GOODer
ecks sacket ley
Seriously! Guy tried to charge me an extra $150 because "your truck, eet dreeped oil on expenseeve convertible below eet, Make big problem for me".
First off, from a weight perspective, why put a pig on upper deck. 2nd, it's an almost 40yr old truck, with an MB motor.....sheesh.
scammer...he knew mo better before hand...
