Rubber seal under hood near windshield
Flooded timber of Arkansas
Mine (see photo of passenger side) is in no way connected to the vehicle. Gravity holds it in place while i shut the hood but there appears to be several places where some form of a connector would be used?
Can i either buy the connectors or order a new seal? Anyone able to find a part number of that seal?
Many thanks!
There are clips that hold it to the plastic cowl which in turn hold the leading edge of the cowl to the body of the vehicle. I had it apart last summer when I repainted my cowl and they're about $1 each from a dealer.
You can see in your picture to the right of your hand the hole where one of them goes through and also the scratch marks of someone prying them from the leading edge.
Has your windshield been replaced. If so, tech removed the clips (which damages them) and failed to replace them. That cowling below the windshield has to come out to replace the windshield and it is also held to the body by those clips.
This is the closest thread I could find to post this question. I am not looking for the same part as the first post. But the trim between the Cowl and glass above. I have circled in red:
If any one has the part number, I would greatly appreciate it. Thank you!
I believe that seal is part of the cowl, as no info is listed on the parts diagram... RH and LH "cold weather spec parts
5578160130​
5578260050​
Both listed as avialable from IMPEX...
I just did my windshield and got all new rubber. My new piece came with those clips from Toyota.
I see both standard and cold weather cowls available. Anyone know the specific differences between the two?
Not certain, but I believe it is just a manufacturing process issue. Either will work unless you live in the extreme cold!
I’m looking for exactly this. Did you ever figure out if you could replace just that trim?
I have been searching for that as well.
Just picked up two spare cowl pieces since I know I broke one of mine. Been searching for that same edge trim since the ones I got are a bit aged.
Here are some shots. Still trying to find an extrusion piece that has a similar profile.
Anyone know if this kind of profile is used on other vehicles? Seems Toyota does not include a part number for it alone.
