Rubber Seal Kits
Cooktown, Queensland
OK you kings and queens of restoration does anyone know where I can buy a complete (brand new) rubber kit for my BJ42 in Australia. I am chasing all doors, windows, roof, bonnet and everything in between so that when I start the rebuild I can replace it all. Thanks in advance.
I believe, in the states, most of the late model weather stripping is still available from Toyota (albeit pricey). I think the early door weather stripping and some of the other pre-1975 rubber is extinct, but I think most post 75 rubber is still available. It has been discussed a little in this thread, complete with several part numbers, and some discussion of alternatives:
https://forum.ih8mud.com/threads/fj40-weatherstripping-guide.734769/
Can't be of more help for Australia, specifically, but I'd start with your friendly local Toyota Dealer!
I have also heard that Cool Cruiser of Texas weather stripping does not fit right - I'm not sure they ship down under, but I'd avoid their product if possible.
Thanks for the info.
x2 on Toyota for weather stripping. May be a bit pricey, but you do get what you pay for and OEM usually fits right!
I rang Toyota in Cairns today and they are going to see what they can find. Will let you all know when I find out.
I replaced all of the rubber in my FJ40 (except under the fiberglass cap). I think that I was about $2000 into it all by the time that I was done.
Here's my advice....This is not one stop shopping.
1) Research Spectors drawings for all of the descriptions of what you need.
2) CDan should be your first stop....he will be able to get you what is still available from Toyota.
3) For the stuff that you cannot get from Toyota. Check the other vendors like cruiser corps...you will be able to find the smaller pieces through them.
Doc
Here is my latest list (4 years old)....feel free to make any current corrections and "pay it forward"
1977 FJ40 Hardtop Restoration List
Hardtop seals
Top Windshield Weather strip Toyota Part# 63131-60011 $47.80
Front roof Weather strip spacer (2 needed) Toyota Part#
Front side Rubber packing RHS Toyota Part
Front side Rubber packing LHS Toyota Part#
Lower Side Weather strip (2 needed) Toyota Part#61524-60011 $16.39 EACH ($32.78 TOTAL)
Pole tab (2 Needed) Toyota Part#65839-90300 $4.63 EACH ($9.26 TOTAL)
Roof Drip Rail Pad Toyota Part#
Tub Side Lip Weather strip 9/72-9/83 40 RHS Toyota Part##61688-90308 $77.94
Tub Side Lip Weather strip 9/72-9/83 40 LHS Toyota Part#61687-90308 $77.94
Foam Cushion- door to hardtop bow section $4.95 (Source Cruiser Solutions)
Foam Cushion- door to hardtop bow section- LH $4.95 (Source Cruiser Solutions)
Foam Cushion- header bar to hardtop side FJ40 $4.95 (Source Cruiser Solutions)
Fiberglass top to Hard top Hardware
Hard top to Tub Hardware
Window Seals
Windshield Weather strip Toyota Part#56121-90301 $41.08
Rear 1/4 Glass (Hard Top Side windows) Weather strip RHS/LHS (each side needed) Toyota Part#62741-90303 $31.05 EACH ($62.10 TOTAL)
RR ¼ Kick-Out window W/strip RHS/LHS (each side needed) Toyota Part#62797-90800 $ 52.22 EACH ($104.44 TOTAL)
Rear Corner Glass Weatherstrip 9/71-9/83 RHS/LHS (each side needed) Toyota Part#62742-90300 $22.72 EACH ($45.44 TOTAL)
FJ40 Door Weather Stripping
Front Doors
Ft Door Weather strip RHS Toyota Part#67861-90300 $68.04
Ft Door Weather strip LHS Toyota Part#67862-90300 $68.04
Run (Window Channel) 1/75-9/83 W/O Wing Window (2 needed) Toyota Part#69105-90300 $77.42 EACH ($154.84 TOTAL)
Weather strip Outer Window Felt 1/75-5/80 (2 needed) Toyota Part#68180-90300 $14.66 EACH (429.32 TOTAL)
Weather strip Inner Window Felt 1/75-9/83 W/O Wind Wing Window (2 needed) Toyota Part#68160-90300 $12.34 EACH ($24.68 TOTAL)
Front Door Window Cushions (4 needed) Toyota Part#67434-90300 $7.52 each ($30.08 Total)
Ambulance doors
Weather strip Ambulance Door Glass RHS/LHS (2 needed) Toyota Part#68291-60030 $48.89 EACH ($97.98 TOTAL)
Ambulance Door RHS Weather strip Toyota Part#68292-90301 $49.68
Ambulance Door LHS weather strip Toyota Part#68291-90301 $51.26
Thanks for the list mate it is pretty comprehensive. I will start looking around.
Was that over in the States mate.
Hardtop seals
Window Seals
Front Doors
Ambulance doors
COPY AND PASTE! Thanks Doc
I dont know if they do here or not. What sort of discount do you get over there.
I used toyota for all doors and aftermarket for all hard top stuff. I am extremely happy. You dont want to mess around with aftermarket on the doors. There are far too many intricate turns.
I would make friends with a toyota parts guy locally or use one of the forum guys.
Enough to make it worth getting someone here to receive it and ship it to you. 25% is not unheard of from some mud members who work for Toyota.
Don't right off Rare Spares right there in Queensland Ken.
Sure their door rubber is "more substantial" than OEM but if you use your cruiser a lot that'll actually mean it'll last longer without causing annoying door rattles and door squeaks (even though the doors might sit a little proud for 10 years and require a good slam to shut).
See my door rebuild thread:
https://forum.ih8mud.com/threads/tackling-the-doors.370889/
And if you get stuff from the states without going through an intermediary person, then Cruiser Corps served me well. (Companies like CCOT and SOR are bound to make payment difficult and have stupendous shipping charges). My experience as a kiwi in a far off land is that they will supply genuine Toyota (and even some parts not listed on their website) and are extremely helpful in all respects.
:beer:
Thanks guys will check them all out. Lostmarbles I have been looking at Rare Spares and their seals look pretty good. I think I was quoted $600.00 for a full kit.
Got the kit Kylie but haven't fitted anything yet. It is not a complete kit as it does not have the rubbers for the rear ambulance doors or the curved windows in the back. Also no seals for the kick vents.
