RTH: won't start using key after engine swap
Mountain House, Ca
So, my uncle and I just finished a motor swap/rebuild on his '96. We tried to fire her up yesterday but won't start by turning the key. But if we bypass it and directly hotwire the starter to the + of the battery she will fire up.
It seems that there is no 12v going through the starter.
Is there an immobilizer on these year/model that prevents the key to kick the starter?
Thanks...
^^All grounds are solid. IF, indeed a ground was missed, would it prevent us to start using the key, but successful start when hotwiring the starter?
If it helps, he has a '96 and we swapped in a '94 with 140k miles.
At first we thought it was the starter and so we took mine off and tried it on his and it's the same, no start using the key.
All electrically were plugged in and nothing was left not connected.
I am using my iPhone so the search button is not cooperating.
Thanks for any input.
John
Mine had a alarm immobilizer system on it when I got it.
It was under the dash, and they had a relay that interrupted the start circuit.
If you find that relay, post a pic and I can tell you how to wire around it.
Or, look for a little toggle switch (valet switch) and try flipping it to the other position.
Looking for that relay...
It does have and it appears to be a factory alarm. It has that tiny red light on the far left side next to where the factory locker usually is.
For now we have made a push button to make the motor turn and not use the key until we figure it out.
The starter motor will only run with the tranny in Park or neutral.
There is also the RS3000 security system that will cut off the starter if it detects a theft attempt. Google it to find the manual which describes how to disarm or disable it.
Did you unplug the black box under the seat?
If not that, then tranny neutral would be my next guess.
To bypass the alarm starter interrupt if you remove the lower dash knee pad and follow the wires to the ignition switch you'll see two plugs with some wires that branch off to the driver's kick panel. If you remove the chunk of harness that the wires branch off from and connect the two remaining harnesses (ignition switch side to chassis harness side) it'll eliminate the alarm's ability to keep the starter from working. There are other wires and splices to remove if you want to do a full uninstall, but that should let the starter work if the alarm is somehow the problem.
Also what @2fpower posted. Should be easy to eliminate this as a source of trouble with a simple bypass wire or two.
