RTH - Rear shocks
slow95z
Always parting 80s
Dublin GA
looks like someone in the past mixed up, or maybe mounted backwards, the rear shock plates. anyone have a pic of what they should look like? here is a pic of my shocks i took out next to the old ones.
the plates can mount either way, and from either side... i just put them up there the way that looked best and hit them with the windy wrench. i guess if i went 30K miles with them wrong whats another 30K right.
The new shocks should have mating flanges that mate to the hole in the mounting plate/mounts.
The picture on the left is correct. The 2 center flanges sandwich the associated mount.
The picture on the right is missing a flange below the top bushing.
I did all 4 corners last week with the new IronMan Foamcell Pro shocks.
i have removed the picture of the shocks since everyone keeps saying stuff about them. trust me, they are bent. the question is the plates that bolt to the frame, do anyone have a picture to show which way they go on? mine are obviously wrong and i just took a guess as to how they went on.
If you square up the mounting plates to the bushing as mounted on frame you should be good. I have swapped sides by mistake once.
Stay Calm & Drive On...:steer:
The idiot had them swapped left to right. it put the top in a bind and bent the shocks bad.
Yeah but they are rusty and I couldn't read them, ga red clay added to the mix didn't help either.
And panic. Add panic to the mix! I've been there...
Lol yup, I am going to repost the shock pic so you see why I was in a panic state. the rear of my truck had been acting odd for a while. now I know why.
Do this to the bottom. You can use tap wrench if tire is not there.
