RTH, another Broken Birf Q...
MTKID
Mostly Stock
Supporting Vendor
Montana
Thanks in advance for any assistance...
I broke the drivers Birf last Thurs. and have dove into it today. Got the busted one out but I haven't seen a definitive as to wether or not I have to disassemble the outer knuckle from the axle. I don't know of a way to otherwise completely clean all the lube out. Am I correct? Also with a "T-seal puller" do you just keep bending the outermost flange down as you work around it in hopes it finally grabs? Maybe my puller is to wide to really get in there. Also, I intended to get the inner axles from Bobby as well as the actuall Birfs but something about my 94' meant they don't have the part? Something about a difference in length between a part about 2" long and a part 4 or more inches long? I am not seeing this part as I have taken it apart. Just the long axle shaft. I am planning on running 37" tires later this summer and wanted to be ready for them.
Thanks, Micah
p.s. built 9/94 if this helps
Thanks also to Dan for his complete help on the phone.
o.k., so I just finished taking it apart. Probably better safe than sorry and I can completely get to all the grease. Mangled the inner axle seal a little more and got some pliers on it. My "T-puller" didn't work. moving on...
o.k. apparently I have asked lame questions so far... how bout' this one...
Is there a Napa or similar part # for the spring clip, retaining ring that goes into the end of the axle shaft where it slides into the birf.? I buggered things and then proceeded to lose it. Local Dealer can order but I would like to continue working on it tonight if I can.
Thanks, Micah
MTKID,
All I can offer is that when I called to order the Longfields, the girl that takes the orders doesn't know a lot about the rigs. I called and talked to Bobby Long directly and he assured me there would be no problems. I ordered the 4 piece set with the Birfields and the inners. I went ahead and got a set of his drive flanges also.
Rich
I wonder what is different about your axles/birfs than mine. I also spoke to Bobby as well as placing my order from his son-in-law. I sometimes wonder if I am asking the wrong questions, but all I want is the front axle upgraded to the extent that I won't be breaking down in the middle of a trail w/ 37's. I don't want to be the person holding up the group when I am a slow one banana wrencher.
thanks for the response.
any ideas on the little ring I lost?
Yes I believe there are two lengths of outer axles.. the longer one is 93-94 iirc, and if you install it on a later model you won't be able to get your dust cap back on, will be sticking out about 1/4" too far, not 2".
So how does that change the inner axle?
There are 2 different 80-Series birfields; 93-94 (shorter overall length w/shorter splines) and 95-97 (longer overall length w/longer splines on the end.) You need the corresponding flange if you are using OEM parts. I think the Longfields are only the longer (95-97) birfield so you will either need the "Bobby Long" flange, or you will need a Toyota 95-97 flange. The "Bobby Long" flange requires some additional work to install larger studs in the hub.
I have both "short" and "long" birfields on the bench right now and can take a pic if you need it.
AFAIK, the inner axles are the same. I do not know if there is a NAPA part for the snap ring but I do know that you can use a wire tie to keep it closed while you install the axle into the birfield.
-B-
There are 2 different 80-Series birfields; 93-94 (shorter overall length w/shorter splines) and 95-97 (longer overall length w/longer splines on the end.) You need the corresponding flange if you are using OEM parts. I think the Longfields are only the longer (95-97) birfield so you will either need the "Bobby Long" flange, or you will need a Toyota 95-97 flange. The "Bobby Long" flange requires some additional work to install larger studs in the hub.-B-
Ahha! Once again us 91-92 guys are neglected! :)
I wish I would've taken the time to lay everything out and measure the differences before I slapped those Long's in. As I stated earlier, I ordered Bobby's 4 piece set and a pair of flanges and everything went together fine.
As far as his flanges, the studs remain the same with the standard cone washers. However, his flanges have slightly larger holes for the two "keeper" or guide pins. He provides larger pins and a drill bit. You just pull out the existing pins, enlarge the holes and install his pins.
MTKID has a '94 and I wasn't sure about the 91-92 so yes, I omitted those years. Do the 91-92 models use the same flanges and birfields as the 93-94? I am guessing the 91-92 don't have the ABS ring, correct?
-B-
MTKID has a '94 and I wasn't sure about the 91-92 so yes, I omitted those years. Do the 91-92 models use the same flanges and birfields as the 93-94? I am guessing the 91-92 don't have the ABS ring, correct?-B-
That is why I said I wished I had spec'd everything out when I had it on the bench. AFAIK, they are the same, yes, except 91-92 has no ABS ring.
I'll measure the birf's I took out and maybe we can figure out the real difference between the <95 and the 95+ birf's.
I have one of each sitting out on the work bench.
-B-
That was a good explanation. So as I understand it my 94' with the VIN plate in the door indicating made 9/94 has the newer longer birf. and that is why the length of the Longfield and the stock busted one are the same. This really has nothing to do with the axle shafts rather the outer flanges, therefore there is no reason why I can't get the long inner axle shafts from Bobby, correct? And is everyone in agreement that those are necessary for 37's? I must be pretty bad at communicating on the phone.
... therefore there is no reason why I can't get the long inner axle shafts from Bobby, correct?
Are you using "long" as an adjective or as a proper name (Long.)? I believe the inner axles are all the same physical length. Maybe some have longer splined areas but that doesn't mean the axles are longer.
-B-
Necessary? Well, that depends on what you plan on doing with those 37's. If you have it apart and are planning on replacing the birf's anyway, I see no reason not to go with the Long's. He warrants them against breakage for life....
Don't forget that they look pretty sweet. That and in contrast to the birfields themselves, won't wear any faster than stock. Lastly, they only add $160 to the price and you get an extra clip (just in case you lose one);):cheers:
Looking through Bobby's brochure again today I noticed what maybe he was referring to on the phone. It lists the inners as "30" spline versus the stock 27 spline. I assume this is the number of groves on the axle shaft where it fits into the birf, right? Therefore it wouldn't fit into the birfs I received from him. I tried calling him today but couldn't catch him. I will try again tomorrow. Also, before ordering another ring, I dug through the trash and found the old one (as my wife recommended). I guess that's what I get for trying to cleanup my work area.
I was using long as an adjective (I think).
And my use of 37"s would be to keep up with the other rigs I wheel with despite my proportions. I have owned it for 4 or 5 yrs now and I wouldn't change to anything else for my family. Local trails are not technical, but hoping to get to Black Hills maybe in March and Moab maybe in the fall. 37's will only go on for the trail as I already have the second set of wheels for them.
Also at some point I will get around to showing some photos of my sliders, which I haven't seen done similarly on an 80 yet.
Micah
Differences
There is a difference in the spline length of the inner axles if you have the factory diff locks fitted. As far as I know the inner end of the short shaft has a longer spline as that is where the diff lock mechanism slides onto when the diff is unlocked. That should be the only difference between the inner axles.
Cheers
Thanks for more info. I finished the passenger side Thurs. and it went much quicker. For now I guess I will leave it alone and replace the next part that breaks if and when I put 37's on it.
Micah
