Build Rosie the 40 - Tilda Bogue Service Station
At first I thought this was the one for the red hood you got from me, quickly realized it wasn’t. What was mine for if you don’t mind me asking? Actually, have you gotten it from Steve?
ian
That is going on a frame off. Ill have info on it later.
Polishing continues….for a paint job where they could not be bothered with romoving removing anything, its very good at least. Polishing up great
The top sides had some kind of sticky funk on them but the CLR cut through it. They polished up nicely. More reflector porn. These are new OEM. This 1969 takes 4. I think he provided 32.
Oh man... if only that wasn't a re-paint. :(
Took the Yokos and City Racer wheels to my guy today since the weather is good. Supposed to rain the rest of the week.
Next I start the long crappy job of rebuilding both axles with 3.70 gears, disc brakes and 10mm brake lines.
Driver front brake shoes were in pieces lol
What is this 2 piece running board you speak of? Like a board and a separate outer band?
Early boards had a base with an upper rubber/vinyl pad and an upper outer ring to secure the pad. In October 1969 the pad and ring were dropped. The board then had a lower frame with a one piece metal upper plate. In September of 1973 the board became a one piece stamping.
Were all the vinyl pads the white diamond material?
At some point I need to find a repro pad for mine. Way down on the list though.
This method of breaking apart the 55 year old bond between axle and third member is handy for old folks
When I pull 3rds for a swap, I always put the rear from the donor into the front. That way the 3rd with the least amount of use is moved to the rear.
