Prob goes without saying, but inspect the other links for condition and hardware nissing.
To echo Jimbo here, prior to SAS I was crawling around under the truck doing some unrelated maintenance and discovered several loose nuts and bolts that easily could’ve spelled disaster.Probably worth doing a "pre-trip inspection" and verifying torque on all the big nuts & bolts below knee level. That's the stuff that can cause damage to life & limb while you're going down the road. I did that before SAS and need to do that today now that I'm back - who knows what happened after a week of beating the truck around on rocks & stuff.
Maybe the toe-in was keeping it together. Going backwards pulled the linkage apart and towards the loosened side, then it let go?pulled in reverse, and the whole thing came undone.
If you had some s***ty aftermarket steering wheel then it was not a bad way to spend your money.Jim, I didn’t stop looking ever since I saw yours, I’m like a hound dog. I had to have it.
Manual steering BJ60 OEM steering wheel. Like a 1980s 40 Series, but brown.If you had some s***ty aftermarket steering wheel then it was not a bad way to spend your money.
I would think that a loose castle nut could allow a cotter pin to eventually be sheared off. Or the pin failed due to rust?
Is there a handy reference list somewhere with the important nuts & bolts to check and their respective torque values?Probably worth doing a "pre-trip inspection" and verifying torque on all the big nuts & bolts below knee level. That's the stuff that can cause damage to life & limb while you're going down the road. I did that before SAS and need to do that today now that I'm back - who knows what happened after a week of beating the truck around on rocks & stuff.
For what it's worth, those ends are not OE. They look practically brand new, and they're unpainted iron/steel. Even a slight whisper of rain would make them get rusty.Jim gave me the clue. I just chased it. No, not 555 rod ends; they're OEs, so never replaced.
I ordered the kit from Man-a-fre back in March of 2025; they're 555. Two things could have happened:
1. Man-a-fre never fully fulfilled the delivery, and I lost track.
2. Man-a-fre shipped the kit, and the shop never installed it.
Either scenario: $150 down the drain. I ordered it again from SOR today; it definitely shows 555. I guess I'm doing the install myself soon. Something something, do it yourself.
In the FAQ’s in fact.Is there a handy reference list somewhere with the important nuts & bolts to check and their respective torque values?
Yeah, you'd be right, easy to miss. I've been under the rig several times, never once thought about it, but I don't claim to be a mechanic or an expert; that's also why I hired a shop. I hinted at this without throwing them under the bus, but I had my rig in a shop for the mechanical swap-out of my motor, transmission, and suspension early last year. I know I bought the kit, so they might have installed the new ones when they installed the steering damper, since both ends were missing pins.For what it's worth, those ends are not OE. They look practically brand new, and they're unpainted iron/steel. Even a slight whisper of rain would make them get rusty.
I really don't understand how that cotter pin even would be missing. The aftermarket joints with that pin installed. It's possible it was a factory defect and they forgot to install it, and whoever replaced the joint didn't notice either. I'm not so sure I would notice that cotter pin not being there, if I weren't explicitly looking for it. ...which I will absolutely be doing now...
This thread has me thinking. When I bought my LC, the PO said the toe rod ends had been done, but I have found that he was not very honest about a lot of things. I look at them periodically to make sure everything looks OK. Is this amount of play correct? might need volume.
You're replacing the rods every time? Or do you mean the rod ends?When I do a knuckle job I usually also replace the tie and relay rods. Relatively inexpensive cost for peace of mind.
Honestly, the way you use your truck for its intended purpose, I could see you bending a lot of rods.
I actually had that very thread with the torque specs bookmarked alreadyIn the FAQ’s in fact.
