Build rocks and rolls
transmission is ready for a novak adaptor and awaiting a centered up tcase
Bump for an sweet build.
Only getiting one day a week on the build.
I picked up a front disk set up on the cheap which I am going to use in the rear. Instead of chevy brakes in the rear I will have toy brakes front and rear.
bucket of hub parts and bearings.
Bearing gas bath.
Replaced the brass in the spindles they were beat up and worn out.
I need to order up some new rotors
I have new bearings and races but they are sill in the boxes and wont come out until the install
Forgot to post these photos from awhile ago.
After removing the rear 22 gallon tank, I had to shorten and reroute the fuel lines.
I am using the OEM tank and the tank inlet is such a wierd fitting and it took awhile to adapt to it.
For the return line I welded a piece of plate on the fill tube and tapped it. Used an existing hole in the floor.
Excellent work! That roll cage looks a million times better without all the tape on it.
