e9999 said:errr...
another thread down for the count...
Maybe so, but what is up with Tyler's Avatar?
What is this? Ancient Rome?
e9999 said:errr...
fj803fe said:Our biggest problem was rubbing from the front tires on the fender well.
landtank said:I've almost posted a thought on this a couple of times. While dropping the front arms will likely guarentee that the axle's alignment is in spec it also changes the path that the axle travels. With that rear point dropped, it now travels up and to the rear out of the wheel wells center.
Was the truck running stock rims? And where abouts was it rubbing?
Junk said:Yet another reason why cloning is a bad idea.
landtank said:I've almost posted a thought on this a couple of times. While dropping the front arms will likely guarentee that the axle's alignment is in spec it also changes the path that the axle travels. With that rear point dropped, it now travels up and to the rear out of the wheel wells center.QUOTE]
Not having the the drop brackets changes the path, the path is more front to back. Having the brackets, the path is the same (sans any travel increase), but the starting point is different.
The trick for not rubbing is that it's centered when it bottoms out - on the presumably lowered bump stops.
Without droped brackets, and just 4" springs, and say 2" bumpstops, when the axle bottoms out, it will be further down and back toward the wheel well than stock, cause it's not coming up to make the arms level. Arms level is the furthest forward the tire can be. With drop brackets, 4" springs, and the same 2" bump stops. The arms go beyond level (pointing up) and start to come back toward the wheel well.
Both ways the tire is down - aka further from the top of the wheel well than stock.
Both ways I believe the tire is further back than stock - but for slightly different reasons. Easiest way to tell which places the axle more in the center of the wheel well at full stuff, is measure a non-dropped stuffed into 2" lower bump stops, and then put the bracket on and do the same.
Thinking about how the tire swings up and forward, and up and backward, with the two systems, and how that relates to a round tire going into a round opening, without knowing the dimensions of all the parts, makes my head hurt. But until someone actually measures the axle position relative to the wheel opening with both options, or provides some dimensions on the arms, and the arm mounting relative to the wheel opeing, it's hard to say one comes back more than the other.
Could someone give me all the dimensions of the stock arms so I can model it? Not that it will settle anything, cause we'll still have people saying naw huh and uh huh, but I just really want to have the information for my own satisfaction. guess in the mean time I'll stick with...
Originally Posted by Riad
, just keep on pounding <snip> until you get off. .
Walking Eagle said:Not having the the drop brackets changes the path.
landtank said:I'm not seeing this at all. How can the path of the arm change if the hinge point remains the same.
ShottsUZJ100 said:2 different lifts for two different applications.![]()
fj803fe said:And this just goes further to prove my point that Germans love David Hasselhoff...![]()
landtank said:Nice drawing Walking Eagle, it shows my point nicely. At compression the axle will be out of position in relation to the wheel well and I thought that might lead to more rubbing.
markt said:dont really want to join in but I couldn't resist. Anybody from here see the results of "Trail Masters" drop brackets for Jeep Cherokees a few (8) years back?
Let me just say....bent/ripped off brackets, cracked/bent frames. I know Cherokees are not built to the same specs as the 80, but the concept of increased leverage is the same. The drop brackets on the Cherokee made it drive better with lift for a while...untill the brackets broke off! I don't see the trail master lift offered any-more???? Most lifted Cherokees are now running Long Arm set ups. This is the route I would like to see offered. It works on Cherokees why not on the 80's. Lengthen the arms and move the brackts closer to the center of the truck so the arc becomes larger. This helps with both caster and ride quality.
