clarkrw3 said:I take it you were the only one in the group that made it up that section?
Yep
Tapage said:I have one idea .. someone with Slee 6" kit doing the same trail ..![]()
clownmidget said:Dave, not to continue to come off as the designated nay-sayer but from the pics you posted it doesn't appear that you were ever in enough rocks to be up on your sliders. I guess when I mean "rock garden" and hanging up on everything under the truck I mean that even with the 6" springs plus the 1.5" spacers plus running 37" tires you are still scraping the bottoms and sides of the sliders, dragging one or both differentials, hanging up on the bottom edges of both front control arms, scraping the xfer case skid, forcefully whacking both rear lower control arms and most likely the rear lower shock mounts and finally exiting with a series of tail end whacks.
QUOTE]
what he said. OR
Where were the rocks?
I saw lots of slabs...
4WD Toyota Owner Magazine said:Well, it's not like the Man-A-Fre kit is only for mall cruisers. It will do fine in most situations except serious rock crawling--which not a whole heckuva lot of 80 owners do--with a few well-known exceptions!
YES. Apparently you need to so we can see them. May want to crap then enlarge the pics tooyellowchaosfj80 said:ROCKS (slabs) LOOKED LIKE ROCKS TO ME! NEXT time we will paint them PINK FOR YA!![]()
-Spike- said:I guess you haven't been following along.
-Spike
ShottsUZJ100 said:I read, but some want to compare apples with oranges.![]()
The 6-inch Slee lift is made for one wheeling type (more aggressive) and is a royal pain in the ass to install.
How are you going to lift the truck if you don't change the stock parts? Not sure I follow this one.It makes many of the stock components non-stock any longer which ISN'T a good thing.
I have the same setup on my Lexus (except for springs) and WISH I DID NOT. IT's been a learning experience.
Let's be open minded about this topic?![]()
sleeoffroad said:[]Thread hijaak in progress]
Huh? Unbolt, then bolt on the new parts. How is that a pita to install? Also, you do not have the 6" lift, you have some of the parts of the 4" lift. You also bought the DIY pieces, so they are DIY. The caster plates are more complicated than the control arms that is supplied with the 6" lift.
Also, it is made to clear a certain size tires, what you do with the truck is up to you. It was never made for just one sort of wheeling. We have lots of customers that drive the trucks long distrance with the kit on it. Yes, 6" is taller than 4" and if you are going to do 90% highway but want to play hard, then the 4" kit is better.
What I do not understand is why you wish you did not do it. You decided to buy what you thought you needed and not what we suggested. So yes, I can see the learning experience, but I can not see where that is the problem of the kit.
Trying to be![]()
ShottsUZJ100 said:It did not work for me. Vibration galore. So, piece by piece my stock 80 got turned into a welded together mess IMO. My '93 went everywhere my buddies go with your 5-inch (Walt).
sleeoffroad said:Uhm, Walt has the same pieces on his truck. The welded parts should not be a mess, unless your welder could not do a proper job. Both eyelets on each panhard rod and control arm are welded by Toyota. Have you looked at some of those welds. Not pretty. So installing the adjuster and welding it in should not effect the stregth of the rod.
Yes, it is an adjuster it adds complexity, but not necessarily a weakness.
As for vibrations, you should not have any when it is dialed in. Not sure if you guys got it right.
ShottsUZJ100 said:I agree! I agree! I'm a bad writer at getting my point out.
What is wrong with that?Yes...yes...my truck will work fine. My welder is great. Never any breakage. But now I have arms with stock welds and NEW welds.
I have different drive shaft(s).
What is wrong with that?Caster plates....blah blah.
No but you wanted a truck that drove well on the road. If you did not want it to drive nice, why not just do the same as the 93?I didn't want all that.
All I'm saying is I wanted about 4-inches lift. I had it in the '93 and without all that stuff. I think the more you alter the truck the more risk you run.
Dogging the MAF lift is like saying the UZJ100 is a POC.
You do that you reveal bias or ignorance and it serves no purpose.
Personally the MAF kit is not for me, but neither is the Slee 6". The 100's not everybodies first choice...but it's mine.![]()
