sleeoffroad said:What is in that kit? Also, as Rick mentioned, get the alignment specs and see what it is. Just because it doesn't vibrate doesn't mean it is right. As he mentioned, we try get all trucks back to factory specs. There are a number of variables involved and one can not always do it. Ricks caster plates are pretty slick, but for most people that buy from us those might be a little above their ability to bolt on. That is also the reason we will not install a basic OME 2.5 lift without caster bushings. Some say you do not need them, but the fact is if you raise the vehicles, the caster changes, so it has to be addressed.
Installing J's without addressing the panhards casues misallignment of the axles. Again, we will not do it without addressing it. Individuals chose to ignore this. Ask anyone with a truck lifted with minimal components to drive it, and immediately get back in a stock truck and give you their opinion. Only then will they realise the compromises they have made.
I agree with the rear panhard drop bracket from MAF, but even with that you might still need adjustment. I do not however agree with the front panhard drop. With a dropped pirman arm, yes, or with the steering arm on the otherside lifted yes, but not on it's own.
Agree with you on this. We never advocate using stiff springs just to get extra height. Use the springs for the load they were designed for.
We do not have to drag the 100 into this.![]()
OK, not rushed any more (was last night). I think I can write properly.
Here's what I mean (feel) by my LX's lift negativity:
I got almost 4-inches in my '93 and at a low cost and it has worked GREAT.
I got 4-4.5 inches lift in the LX though at a FAR higher cost and with FAR more labor and part modifications.
For the added .5-.75" lift the LX has over the '93, it was a rip-off to ME. Not worth it. A PITA. Am I happy now that's it's done? YOU BET! I'd NEVER do it again though.
That's all.
