Build Roaming Lost: x3 Locked 1990 Toyota HDJ81
Whole Lotta nice. I dig the redarc gauges. I look3d and couldn't find a dual with egr and boost. I may have to reconsider. How different with the new turbo and intercooler vs. Stock? I'm guessing dramatic. What boost did you settle on with the gturbo?
I've debated back and forth about a turbo swap and intercooler on my 94. It's still pretty low miles at 218k kms.
oh yeah big differance! im at 18 psi and soon ill be going to a 4" snorekl to custom airbox that will have a 4" inlet and outlet so itll provide more air flow that should benefit.
Are you looking at a 4” Stainless snorkel I presume? Just a fair warning - I had the same set up you’re after (GTurbo, IC, Airbox and 4” snorkel) it’s going to be like really really loud.
It hurt my ears with the window down and under load, really affected driveability unfortunately. Sounded rad at idle though.
yeah, a buddy makes some small-batch ones. but noted! i guess we will find out lol. i think it will benefit from the air tho.
Welp, Not exactly what I wanted to spend money on, but the whole power steering was rebuilt/replaced.
Rebuilt the box with a 105-sector shaft. New pump. I found out that we got some cracks in the frame... so they welded it up as a temp fix till I go back to get some proper plates to fix.
If you're in central Oregon and have an import, definitely check out Technique.
I've been battling overheating. I've been hitting 105 C often. I started with a new rad cap and thermostat but didn't do anything. Then, I installed a new light blue wheel-modded clutch fan from Redline Cruisers, That kinda helped. Next up is a new CSF radiator and hoses.
