Rewiring Question?
I bought a 79 Cruiser and the wiring was all hacked up and pretty shady. So I went ahead and cut and gutted all the wiring all out. I went ahead and put new battery cables on it. I ran wiring and a fuse on a toggle switch for the coil and a fuse and wiring with a push button for the starter. Ran a wire off the alternator to the battery for charging. I have heard people talking about some kind of solenoid on the carb. Do I need to wire this or what? I looked on the carb and I see something electrical, but the wires are cut off clean. Is there anything else that needs wired? I don't need lights, horn, etc. Any help would be great. Thanks.
Brenton
That is pretty minimal Fred Flintstone style wiring.
An alternator is pretty useless without the voltage regulator and something to energize it. The carb solenoid should help it idle if you have a 2F. Gauges are pretty useful, but so are lights.
Understatement of the year..........
Man. I am glad I found a website with smart asses. Maybe before you open your mouth you ought to ask what the vehicle is for. And I put in guages, but thanks.
I thought the "Idle Solenoid" is really an "Anti-Idle solenoid", tat keeps the engine from running when the ignition is off - Maybe that's what Pinhead means when he says it helps it run better if it is connected.
Does it run now with the solenoid disconnected?
Rocky
"Is there anything else that needs wired? I don't need lights, horn, etc. Any help would be great. Thanks."
so what kind of harness are you using?
You can get it to run without the solenoid on the carb energized, but it'll run like crap unless you have the choke engaged. Hook it up to the same circuit as you are using to power your coil - that way it won't be energized permanently.
Also, this ain't pirate and we don't want it to be so watch your mouth.
Rompin;
Just curious, is the FJ40 equipt with a 2F engine and stock carb?
If memory serves, the carb has an idle cut-off mechanizism so that the engine doesn't run-on when you shut off the key. I'm fairly sure the alternator has built in regulator.
A really helpful manual is the "Toyota Landcruiser Repair Manual #98154".
The Haynes manual #313 is also useful, but not as detail oriented.
Welcome
The regulator is outboard, typically mounted on the firewall by the steering column. On the carb is the fuel shut off solenoid to keep it from running on at shut off. Without this, it will refuse to idle till you get into the choke's fast idle circuit. Early ones are one hot sire, and ground thru the motor, later ones a two wire, one hot, one ground...
A good schematic is going to be your friend thru this.
The alternator is internally regulated. So I think I have that figured out. Thanks guys.
What's this vehicle for? Driving? Thats what mine is for, but I have seen some good looking garage queens that wouldn't really need wires anyway.:princess:
That guy gives a lot of good advice for free, and you scored a little info that you might not have known in that post too. Don't like his humor? Whatever, but that's really no way to talk to someone who is trying to help you out. Maybe you should sell your cruiser and get a Jeep.
Actually its a rough cruiser that I picked up cheap that I am going to 4wheel til the wheels fall off. So I won't need a horn, windshield wipers, running lights, turn signals/brake lights, etc. Sorry I was snappy earlier, I thought he was talking me down. Anyhow thanks guys.
Unless you do all dry, or windshield down wheelin, I'd rethink the wipers. And unless you only go wheeling alone, or with seasoned telepathic drivers brake lights might save you a few bumps here and there. But these are not part of the minimum to get on the trail.
