Rescue 1977
Hot Springs
Tried to buy this old girl 20 years ago , but fate comes around again , but a flash flood submerged the old girl , owner passed and now the kids want the money to go to their mom , i want to be fair, what type of value would you throw out on a 77 with a year of flood damage , pulled the stick and oil is at the top , water below I kicking the 2k to 3500 range , might be high but there’s no cancer only surface scale
You're going to have to rebuild the engine in all likelihood. You will probably have to rebuild the trans as well. If you are lucky, you can just pull the plug and find it has good lube in it or just needs to be disassembled and cleaned.
$1000 maximum.
I bought a '69 that was flooded in hurricane Sandy. It was much more work than I expected to just get it back on the road.
Was it in a river or lake? Some water is more corrosive than others and it looks like it was not flushed out after the flood. My guess is about $1,000 - 1,500. No More but it depends on how bad you want it. I bought a seaplane that was submerged and spent over $200K to get it back airworthy. Lost about $75K when I sold it but needed to move on to another profitable project. Good Luck with your decision.
Probably figure a lot of hidden issues.
if water is in the engine it is in the steering box, trans, transfer and both axles, all are going to be bad not worth salvaging, axles could be rebuilt with replacement diffs. next is all the wiring and connections. did the doors drain the water out?
personally I'd be 1000-1500 preferably closer to 1000.
Body should clean up to a nice patina! mechanical thats a big full rebuild on everything. Id say 1200-1500 max
I would closely for rust along the bottom edge of the ambulance doors, front doors, rear corners of the hard top sides, floor pans, rear sill and frame (rear gussets and inside the holes). If there is only "surface scale" rust, I think the upper part of your range (2500-3000) is quite fair. It is really hard to those parts that don't need rust repair in the south. However, if all those parts will need repair, I would pay less than $1000.
I'd have a hard time going $2,000 or more for that. :meh:
It may not have "Michigan" type rust but it looks like the door bottom shows some aggressive cancer. I would expect to see the same at all other doors and some other areas as well. Coupled with the probability of all drive line components needing serious attention I would offer $1,000 - $1500. You may be better off finding one for $3,500-$5,000 that has not been submerged.
I think there is a lot of value there, the windshield and hardtop at todays prices would alone be worth 12-1500. The doors may have rust but the tub by itself may be worth 1500 or more. Buy it and then if engine, trans etc are toast I bet you could find replacements for less than a grand, except for the engine. I’d pay 3000.00 in a heartbeat.
[/QUOTE]
X2 on this. Parts value here is good. I would try $1500 ish and work up but there’s some value here. Kind of depends on what your plans are. Worst case, you won’t lose $ if you decide to part it out.
[/QUOTE]
you guys are seeing the parts cost/sale price, there is a bunch of labor involved and things may sit around for a bit before it sells.
A clean title, alone, has significant value. A vehicle without a clean title in my state requires a bond. Also, if you are in a smog inspection area, a '77 could be the wrong vehicle to start with. However, if you have the space, and a trailer, the body, glass, and or frame, could be worth the effort. Just because the front fenders, rockers, and quite a bit else show only surface rust, and not paint over bondo in the pics, is significant.
I always figure that you offer what it is worth to you, rather than what it is worth to them. The biggest unsung issue with a truck like this is the time and space that you can employ for rebuilding it or parting it out for personal use or whatever.
Big question, what are the owners asking for it?
