- Thread starter
- #161
Those hoses going to the transfer case are on the same switch circuit as your seized cable. My hoses are original on my 71 and aren't pretty but work great. Would be nice to get that seized cable out of the way and see if you can manually test that switch, you might be surprised. View attachment 2675344
The vacuum switch sends vacuum to the actuator on the transfer case. That knob on the dash (that you appear to be missing) only switches between 2wd and 4wd. The lever next to the heater is a direct linkage to switch between H-N-L.
Ok so let me see if I understand this. The knob on the dash which should say FD pulls a cable that creates vacuum that switches the transfer case from 2wd to 4wd. The lever to the right of the steering wheel and left of the heater box switches the transfer case between H-N-L. So if my cable is rusted solid, how do I test the switch? Is this cable available on market someplace. You mentioned testing manually. How do I do that? Thx Mark
