Replacement Landrover axles
Hi Guys, Just joined the website. Its great.
I have a landrover 90 and am sick of breaking axle parts. People tell me that toyota axles are ultra strong in standard form so it seems the next logical step is to fit these to my truck. Here in the UK I can pick up a front and rear for £400 off a landcruiser VX. I think these come with disc brakes and lockers but not sure.Is this the Fj80 axle
Can anybody help with infomation on wether these will be the best option to fit.
I regularly offroad and am using 35" tyres with the standard Defender engine (120bhp)
Thanks for any help you can give me.
The 80/81 Series have optional front and rear electrical diff lockers. There is a code in the VIN sticker to confirm if the vehicle has them, but It may be a different code in your market. Best way to confirm is to look at the axles themselves; if they have lockers there is a small drum with an electric actuator attached to each differential. There is also a wiring harness required for the lockers, but if you're swapping into a Landy you could just make your own.
MOST have a full-floating rear axle and rear discs, but not all. I understand that all the locked axles are full-floaters with discs, but not 100% sure on that.
Might also check on Discoweb.
I know some of the Rover guys are swapping in FJ80 thirds and then using Longfields. I’m not sure how they are mating to the hubs though.
Username "Discyota" swapped some under his Discovery, he might have some useful info, search his threads.
Welcome to Mud!
(glad you're seeing the light...! :D)
maybe you could look into getting the control arms, locker ECU etc as well to make the swap easier, if possible at all?
You DO NOT want to do this swap. Here is why...
Once you swap out the axles, you will notice that other parts will begin to fail more often. This will lead you to cannibalize another 80 just to make your LR more competent. Soon you will have a strong desire to swap out your LR's engine for the vastly superior 1FZ-FE, this of course requires a tranny swap. -See where all of this is going? Cut your losses while you are ahead. Listen to your inner voice...buy a Land Cruiser and be done with it.
Once you swap out the axles, you will notice that other parts will begin to fail more often. This will lead you to cannibalize another 80 just to make your disco more competent. Soon you will have a strong desire to swap out your LR's engine for the vastly superior 1FZ-FE, this of course requires a tranny swap. -See where all of this is going? Cut your losses while you are ahead. Listen to your inner voice...buy a Land Cruiser and be done with it.
What he said...
well, to be fair, he isn't actually talking about a disco... ;)
Check out Rovertracks (or something like it). He has a kit that allows 80 diffs to go inside the landy housing and then you can use stronger front and rear LR axles and bits.
Or just simply get a LC!!!
All UK market 80 series got axle lockers but watch out for imports because very few of those do. £400 for a pair of 80 series axles with lockers is cheap so make sure it is 80 series you're getting and not 70. Auto's and manuals have different diff ratios so you may care which one you get.
Or just do what my mate did - got fed up with breaking stuff / watching me walk stuff he failed - so he ditched his Landrovers and got 80 series Landcruisers instead.
Jon.
Minor corrections pertaining to US spec vehicles....
The axle code (A294) is on the tag inside the driver door. The VIN does not identify the type of axle or the diff-lock option.
All F&R diff-locked 80-Series have FF rear axles and disk brakes (front & rear.) As Wildsmith pointed out, all UK spec 80-Series came with F&R diff locks. The best way to be sure is to look at the axles as IronYuppy mentions.
A US Toyota dealer can use the VIN to pull the Monroney and determine if the vehicle was originally built with the F&R diff lock option. Dunno if the UK dealers can or will assist.
-B-
Welcome to Mud!
What he said...
Dont deny the obvious.....
BTW: Welcome :flipoff2:
Cheers guys, loads of info there to get my teeth into. Due to the amount of £££ I have in the truck I cannot make the leap just yet. I need a bit more suffering before I switch entirely.However I do like the look of the short wheel based early landcruisers. lifted ,caged and some agressive mods they would look wicked.
Thanks . Dave. :cheers:
I thought the LR axle ratios are lower than the factory 80 series ( 4.10 ) are you running LT230 t-case ?
A fellow club mate has a Disco that he put a mini truck third in the LR axle housing and then went with 30 spline hybrid axles. To be honest, I think it would have been cheaper and easier to source a locked 80 series axle and change the flange and suspension attachments. He's been after me for a high pinion third for his front axle. Another thing that can happen is that you can get rid of those LR wheels and go to a 6 on 5.5 wheel which are usually cheaper and easier to source (maybe in the UK LR wheels are cheap and plentiful?).
I would search in the Disco forums this is getting to be a popular swap. When I've had 80 axles for sale I always have had tons of inquires from LR guys. So I'm guessing it well documented on the web somewhere.
I do run the Lt230R transfer box and 3.54 diffs but as i also run 35" tyres the 4.11 toyota diffs will help lower the gearing to an acceptable rate. At the minute it is approximate 26% too high.
I have had landrovers for 11 years and f you can get around the things that brake they are good trucks. What I like about them is they are simple to work on which can be a big help in some of the situations where things have broke.
Cheers Dave
I'm not sure ( but know yes it have ) much reduction have the LT230 in hi .. I know it's a pretty strong t-case with nice hi and low reduction .
Cheers Dave
so, Landys need ditch ladders to go over a few pebbles, eh...? :D
j/k, I like them too....
