My resonator broke in half during Cruise Moab this year.. Drove back to Colorado and it cooked my passenger tail light and tailgate lock. That is all fixed, and got a low mileage stock resonator pipe in good shape to replace the bad one.. However i cannot seem to be able to remove the old pipe over the frame cross member.
The clearance between the crossmember and the body is REAL tight.
Has anyone ever removed this pipe WITHOUT CUTTING it? i will also need to put in the new one, and would prefer not to cut it..
So 80 Gurus, what is the magic to removal, replacement without cutting it ?
- remove the panhard bar to allow more clearance ?
- loosen the body mounts on passanger side ?
- Twist just right ?
How did they get that pipe with the bend and flange ears over that crossmember to begin with?
I have searched and searched, and find many references about removing the resonator, but nobody says how they did it other than cutting it off.
Any help appreciated.
(see post #21 for solution!)
He said working pipe in/out.
