Removing Doors - Help
You could try some penertrating fluid on the hinge pins, let it soak overnight with the help of an assistant to take the weight of the door or leave the door closed and with a pin punch gently tap out the hinge pins in an up-ward motion, there for not having to undo the hinge bolts that are painted.
Hope this helps.
ATB
Nails
Unbolt the hinges?
Were the hinges and pins painted on the truck or were they disassembled and painted?
If it was painted assembled, I think it is going to jack your paint trying to take it apart..
If you try to push the pins out, you might want to fold down your windshield first...
Shawn
I think he means removing the top hinge pins. Only way I know to do it without scratching the paint is to fold down the windshield. When you put the pins back in, put them upside down. If they fall out, you need new hinge bushings. Get the brass ones. ;)
Be sure to unbolt the door stop, roll the window down, and then remove the hinge pins while the doors are closed.
yea , looks like the body/doors were painted assembled. I am going to try and insert a pin from the bottom and ease them out , but it just look like its gonna screw the paint . The other option is just run with the door on. Thanks for the help.
....If they fall out, you need new hinge bushings. Get the brass ones. ;)
Get the brass ones if you want ... but I don't think they give you any advantage.
These are 30 year old pins and bushes from a driver's door that's had a lot of use (but they have been kept lubricated):
PS. The top pin has had part of its head removed so it could be puched out without damaging the windsceen paint.
:beer:
:beer:
the plastic ones on my truck were wore pretty thin from removing the pins over the years, i replaced em with the brass ones and lubricated them and im sure they will last a number of years and will easier stand abuse and neglect.
i also took a file to the upper pins on mine so they would clear the windshield frame
I haven't found lubrication to help a whole lot - I just whack them
the paint was already scratched when I got the truck :meh:
I am pretty sure I would have lost pins already if I ran them upside down, regardless of bushings
what I found, however, is that the top pins are shorter than the bottom pins - not sure whether that was OEM or a PO modification :meh:
what I found, however, is that the top pins are shorter than the bottom pins - not sure whether that was OEM or a PO modification :meh:[/QUOTE]
Is the PO....top and bottom are the same size.....Its not a bad mod...you can remove the doors w/o taking the top off and leaning the windshield forward
My plastic bushings were trashed on the driver's side and I don't think they had ever been removed. Had to take a cut-off wheel to the bottom, thought they were factory peened. Bought the brass ones because it's a no brainer. Think I might replace pins with SS bolts and nylock washers for further removal whenever necessary. Any reason this is a bad idea?
the new pins I ordered from Kurt are the same size indeed (but then, they could be modeled after a later model truck), but I cannot see any traces of a PO having messed with the old pins I have - their ends look untouched from what I can see :meh:
the nylock nuts won't hold after several uses and could come off while driving, I guess
Yeah, good point. I'll probably replace the nylock nuts at least every other time.They're pretty much a one time good hold, second time fairly good hold item. I plan on doing it for the ambi doors also.. Bought bras for them as well.
thought the pins in the ambi doors didnt come out and the hinges had to be unbolted? or sis you cut the pin out and replace it with something else?
Anybody got a part number for those brass bushings?? Where do you get them??
Thanks,
Richard
southbostonfj sells them, i sent him the money and had them pretty fast good guy to deal with, he answered my questions prompltly.
on a side note, your 62 isnt red is it?
My ambi doors have the same diameter pins and bushings as the front doors except the pins for the front doors are longer and have a knurl at the top. Got my brass bushings from this guy.
Alex Durso [alex.durso@feccables.com]
