Removing Doors - Help
No sir , Blue, 8B2, a little faded...
The 40 is Red...
Doing a Power seat Mod, should finish up this weekend, then I Finally plan to get some Pics up...
Thanks,
Richard
Hey guys! As you can see by my pics, my BJ is in pretty tough shape. I have rust all over the place, and at this point I am just making the best of it. Once I get it stateside I will purchase a tub to replace the body, and collect aluminum, and fiberglass parts to finish it off. Anyway, I just purchased SuperTop two-piece doors, and a SuperTop. I simply cannot get the pins to budge! I have tried lubricating fluid, and smacking the tar out of em from the bottom all to no avail. They won't budge. I need help! If anyone has any tips for me I would be very grateful. Thanks!
If you don't lower the windshield, you can use a putty knife to keep paint from scratching. Then touch the head with a grinder to make a flat side that you insert towards the W/S when reassembling.
Turn lower pin upside down to whack frozen upper pin (if it's cut and recessed). Try heat if it's totally frozen. PB Blaster if you're worried about the paint, kobi.
My doors were on/off so much I welded a piece of wire to the tops of the pins and they became very easy to remove.
I'd just get some touchup paint and.........touch up the scratches. there should'nt be too much damage.
I don't plan on ever using door pins on this particular body again, so I am not worried about making the pins easier to remove later, I just cannot get the darn things to budge! When you say use heat, do you mean like a torch flame? Being in rural Dominican Republic, I am lucky to find WD-40 let alone PB, or anything else that could help! I am tempted to just order all new hinges, and install them on the body, but that will take me two weeks at least. :(
Been trying to come up with a good way to pop my front door hinge pins (hard top). Thought about turning a bushing to just the right size to clear the pin head and using a clamp but I don’t have a lathe. Went through a bunch of hardware lying around with no luck but today measured some bushings in an old mini jack set I have and found a perfect bushing (see “c”) that sets right around the pin head (without hitting the rubber) and allows the head to move through the bushing’s I.D.
Applied nice, even pressure with a large KantTwist clamp and the 30 year old, painted/rusted-in pins just popped loose. Then drove the loose pins out easily with a punch and a small hammer - hardly any damage to the paint.
Windshield was folded down out of the way. Didn't get any pictures for once but it should be clear from the attached. The small block on the clamp was on the small, tapered end of the pin. No heat and no banging things up.
Hinge Idea
Don't mean to hijack or anything, but I had a similar issue. I had hard doors on a oem softop 40 and had a heck of a time getting the doors on or off.
So i upgraded to these quick hinges by mc offroad
Easy install and much cleaner on and off. To get them off though I used a good amount of pb blaster just to make sure they came off smooth. Even with this I broke a driver's side door bolt.
Take your time and it'll come easy.
Hello,
In reading through all the posts on upper hinge pin removal. Seems like installing a shorter pin in the top hinge is an easy fix to make removal easier in the future.
Is there any reason not to do that?
Just in the process of painting my doors and was thinking of cutting down the pins when I reinstall.
Thank you!
Disclaimer: When I searched this was the only thread I could find that mentioned anything about hinge pin length.
Hello,
Thank you!
Okay, I finished with my "Hinge Pin Project"
I created a short video. All pretty self explanatory stuff but just shows some of the ideas that were mentioned.
