Removal windshield frame pin
Vancouver, Washington
How do you get this pin out? I currently have two screws that i cannot remove one is stripped the other stuck. One hinge i can remove from frame. Whats the best way to get this pin out?
Can i do in
T while iys still on the vehicle?
@sambudo
It's always a matter of how bad the corrosion is.
If PB blaster does the trick, thank your lucky stars.
I tried all kinds of penetrating oils, to no avail.
I finally bit the bullet and drilled out the frozen pin pieces.
@workingdog :
Been there, done that. Your hinges may be easier, but this is how my hinge disassembly worked out.
Three on-and-off days and more than a dozen drill bits later, I now have 'disassembled hinges' ready for new hinge pins:
You can see some half-moon pieces of the last of the old pins, one hanging out of the hinge at 6 o'clock, the others on top of the hinge to the left. The stinkers didn't let go until the last drill bit basically pushed the remainder of the pins out of the hinge.
On the hinge at 6 o'clock, you can actually see the remnants of the serrations that are next to the head of the pin.
I used SOR stainless steel front door hinge pins and the plastic bushings that came with them. I painted the inside bores with some high-zinc primer.
I tried penetrating oils to no avail, and ended up using propane to heat up the hinges; the pins came out with no problem after that. I did however have to blast and repaint.
I find a 50/50 mix of ATF and acetone works really well for cutting rust.
I have a cool tool that goes in an air chisel for the screws.
As for the pins, same air chisel/hammer with a pointed bit
