Alright, I've been searching for a while and haven't been able to find quite what I'm looking for.
I read through this entire thread that had some helpful info........
https://forum.ih8mud.com/showthread.php?t=93169&highlight=relocating+shocks
But here's my dilemma. Some of you may have noticed that racerdave recently installed some OME comp springs in his 80. Well I am picking up his J springs that he pulled off to put them on my rig. I'm thinking that things should work just fine but I'm having some thoughts on my shocks.
My current setup on my rig is OME mediums f/r with 1.5" spacers. My truck has the old "wristed" Outback control arms and Slee panhards so caster etc is good. I am running 315's and have been the whole time I've owned the truck with no clearance issues. As for shocks I have some RS9000s that were on the truck when I got it. They have worked just fine and I actually quite like the adjustability. I don't have compression or extension measurements yet but I'll try to get them, but they seem to have ample travel with my current setup.
I'm trying to figure out if I'm going to run into issues maxing out the shocks when I install the J's on the truck. As for weight on the truck is pretty light. I have a modified ARB front bumper with no winch and that's it currently. But I have some Marlin sliders that will be going on shortly as well as a WildYoats rear bumper.
Any thought's or advice for me? Also, I have been thinking about just relocating the shock mounts. In the thread I listed above the eye-to-eye shock bracket conversion caught my eye, but would require me to change shocks anyway to get eye-to-eye shocks. Another thought I've had was just to weld a small plate in a bit lower for the front upper shock mounts to drop the upper mounting location. I would need to figure out something similar in the rear I guess.
Bottom line is I'm not sure if I'll even run into issues, but want to have a plan in place since the truck is currently my wife's DD.
here's shot of how the truck sits right now (with the exception of tires, it's got 315 AT's at the moment instead of the MTRs)
And I use ALL the travel available with the "L" shocks and my rear J spring setup.
