Mike,
Greg can help you paint the drive shafts with candy stripes.
juane
juane
Yes, the diffs are going back in on Saturday, one way or the other. The rear is almost ready for the axles. Right hub is back on and the parking brake adjusted. Just need to bolt up the caliper on that side. I should have the left side finished tonight too. Brake system is flushed and all 4 calipers loaded with new pads. Drive shafts cleaned and lubed. Birfs disassembled, cleaned, and packed. I'm swapping sides this time. Still need to drive in the knuckle bearing races and start putting the knuckles back together. New lower knuckle studs and nuts.
Reassembly should go fairly quickly tomorrow.
-Mike-
. Mike has broken truck now...Rory worked on truck...Rory's truck is always broken...
Don't let Rory work on my truck.
