red hot down pipe
Boone, nc
I got out of my 80 today after work and for some reason decided to look into the fender well and noticed that the down pipe between the can and the ex manifolds was glowing red hot!!! My temp gauge did read un-normally nor did the car act funny in any way. Is this normal? The first thing that came to my mind was a clogged cat, could this be it? Any other suggestions?
Thanks.
No no lights at all and they do work ( when the key turns on). I didnt think somethin like that would be normal, so far one vote for clogged cat, anything else? how would i check the cat? May be a dumb question but it seems like it would be something that is sorta uncheckable...
Thanks buds
x2 on the plugged cat.
Unbolt it and see what falls out....
If it won't unbolt or you're unsure, take it to a reputable exhaust guy. They can torch it out, check it, and weld it back in if needed.
Boone......
check out Walts radiator and muffler shop in lexington. Well worth the drive for me, just dont tell him i sent ya :D. Did real good work and at a great price. Those y pipes are expensive so dont toast it. I got a Catco 7'' brick universal cat for under a 100 installed. Another local member had cat and new muffler installed for 250. Just go early or be prepared to wait. HTH
Good advice jfz... I'll get some pb plaster and see if i can get that thing off, if not i'll just buy a new one and have someone weld it on for me. It probably needs a new one regardless.
I was wondering about a lean fuel issue as well but couldnt see how that would happen. It doesnt run hot its just the down pipe that heats up, which really makes me think cat, but we'll see. Thanks for the help.
After a little thinking on the subject i'm wondering if i should not just eliminate the cat. the only reason (2 reasons actually) for not doing this would be 1. Loss of low end torque due to lower back pressure and 2. noise.
Has anyone that has done this noticed a loss (or gain for that matter) in low end or midrange torque?
How noisey would it be without the cat? I really dont want it to be really noisy.
well its a 91 so the cel will not be on since there is no o2 sensor after the cat anyway, and i do not have to pass emissions just safety. Thanks for pointing that out though.
Any one thats dont this know about the other questions i answered...
Thanks yal.
