A friend and I are looking at building some new rear LCA’s. Before I order metal, does anyone happen to know the OD of the bushings? I want to make sure I get the right size tubing.
upper or lower?
Do you want the bushing or the cup measurement?
Your tubing is limited on the UCA by the pocket it sets in. Mine hits/binds on the side of the pocket.
Have you considered reusing factory cups?
Hmmm. Good options. I was looking at the Landtank design. Figured you couldn’t go wrong with OEM bushings in a stout arm. Problem is Wits End is out of stock on them, well he’s out of stock on the bushings anyway. I’m running a J-loft with a lot of weight so I figured I’d extend them to 29cm on center from 27.5. Also have thought about just using Heim or Enduro joints. It would be easy to get some thick wall tubing threaded at my buddy’s machine shop to fit them.
forum.ih8mud.com
