Rear elocker
Starting to track down some locked thirds for my 97 80 series and have a quick question.
Are all 80 series factory locked rear thirds the same? Is there a full float and a semi float type? Thanks.
From what I understand:
There was no factory 80 series semi float e-lockers that I know of.
The only SF locked axles were with aftermarket (ARB detroit etc.) lockers.
The only variation of the rear E-locked axle was the japanese markets, which had 3.73 in some of the diesels.
The majority of locked axles will be identical with 4.11 ratio gearsets, in exception to the JDM, and there should be a few domestic axles in the classifieds.
Also some write ups of the differences between open and e-locker axles in the 80 series section.
There also may have been very slight changes in the US 80 series rear E-lockers from 93-97 as there are three different part numbers each succeeding the previous. The parts gurus would know the details but AFAIK they are all interchangeable between those years.
Don't forget that the axle housing of the locked and unlocked axles are different and an unlocked housing will require modification before you can bolt the 3rd in.
I know this is the case for the front, but am trying to confirm if it's the case for rear as well (that an unlocked housing needs to be notched to accept a locked 3rd) because I'm finding some conflicting information out there.
Do you happen to know for certain either way? Thanks!
Yes an unlocked housing has to be notched for an elocker. 2 studs have to be relocated and replaced with much longer ones, also.
