I did a quick search on this, but I did not find much.
Me and a friend (thanks @frogers935 )installed a suspension lift on my 97 LX 450 this past weekend. The bottom of the rear shock goes over a small tube that has threads on the inside, and the tube is welded to the axle. The shock goes over the tube and is held in place with a bolt that gets threaded into the inside of the small tube.
When we installed the shock, we noticed that the threads on the bolt were badly stripped, as were the threads on the inside of the tube. We could get the bolt tight enough not to be able to unscrew by hand, but it is very loose when tightening the bolt using a wrench. We tried to re-tap both the bolt and the threads inside the tube with no improvement. I have driven the vehicle like this for about 50 to 60 miles this weekend, and the bolt is still in and still can not be turned by hand.
Has anyone else run into this issue, and if so, how did you address it? @frogers935 suggested a helicoil, which involves drilling out the threads on the inside of the tube and putting in a threaded insert into the tube, but there are concerns about over drilling the tube and reducing the thickness of the tube by too much. Not sure if thread locker would help if we left the threads as is.
Your comments or suggestions are appreciated.
