Re installing bumpers after 2" BL
Has anybody moved bumpers up to the original alignment , after a 2" body lift ?
Why do a 2" body lift when a 2" suspension lift is so cheap and easy?
Yeah, the front bumper will be tough to move because it is formed to the front.
The rear bumper is the frame........so........it's gonna stay where it is........
I imagine you could probably make some new brackets to raise the front bumper, but the frame horns will probably interfere with the bottom of the bumper a little bit... might need to cut a section out of the bottom of your bumper. Not sure how that would look. Bilt4me is right, the rear bumper is not going anywhere, it is part of your rear frame cross member. Unless you want to cut out the crossmember and build your own rear bumper. That seems like a lot of work for a body lift :o
What is your reason for 2" BL? As mentioned, you can probably achieve whatever you're after via suspension lift or a 1" BL.
Doing an "Arctic Truck" build on 44" x 18.5" x 15" Dick Cepek fun Country's.
I'll have to pull some of my Iceland research and see if I can get some clues at to what's possible/practical (re-installing the bumpers is a little beyond my current planning horizon)
If removing and re-installing is beyond your planning then hold on for the rude awakening you're going to have when you realize you have to do some serious wheel well and fender trimming to properly fit the 44" DCFC's and if it's the same 96 that's in your signature line you're going to be doing some caliper grinding also which isn't terribly safe. There is a reason 92.5-97 cruisers came with a 16" wheel over the previous 15" wheel. 15 doesn't fit over the calipers. Using a steel wheel with proper backspace may alleviate that issue somewhat. However, be prepared to trim the rear wells a bunch, and the front fenders, floor board and lower core support (the part that protrudes from into the fender well up front. I am a huge fan of the Arctic trucks, want to make an Arctic 80 myself one day if I ever move to a climate that I could use one.
Perhaps someday I'll start a thread on how to manage/avoid the points Cruisin raised. But for now the topic of this thread is bumpers & 2" BL
well, if you can manage all that, I'd say just make some new brackets to lift the front bumper. Cut off the rear crossmember and make your own bumper. Or just make your own front and rear to your tastes. Bodywork looks very clean behind those flares and 44's look GARGANTUAN on a 15" wheel :cool:
These are Formverk Fender flares. I found two shops in Rekyvek that would respond to my emails, and could roughly respond in English. I exchanged emails with 2-3 English speaking Iceland wheelers, and received favorable comments on both shops. With the only comment that Formverk does the door sections better. Formverk is the same supplier for Arctic Truck, and seems a little more professional. Formverk is significantly more expensive, but I was up against a deadline and could not cross the language barrier quickly enough with Gunnar's shop to make the last direct flight from Rekyvek to Anchorage last fall.
When I first saw the question, I figured another 18 year old with Mom's old mall crawler.
Guess not...........
Why do you want to maintain the stock front bumper? Wouldn't you want a winch and protection for the front end from deep snow drifts? As far as the rear bumper, trim the rear crossmember if you must. Otherwise build some armor back there as well. I realize you want to keep weight to a minimum, but you still need protection from mother nature.
I LOVE the Arctic Trucks.
Good luck.
My winch will be synthetic rope and on a receiver hitch, so it can be moved front to back
Regarding snow drifts. The fellows that wheel this type of build watch tire air pressure very closely. Maybe the best snow layer is on top, maybe it's 8" down ? But in any case, not all snow conditions are wheelable, it will never be a snowmobile. I've got a lot to learn for this type of wheeling, but not sure I'll get very far if conditions call for pounding a lot of drifts.
But in any case, if I have mounts in the stock location, and stock is not doing the trick, I can slide on the ARB in the back yard, or any off-the-shelf solution for an 80 series
I've watched a lot of their videos and they seem to do a fair amount of ice busting and that would wipe out a stock bumper pretty quickly.
The tires used also make a huge difference and the seem to have one preference up there.
If you look at some of the Russian built rigs, they do it with much wider tires and a bit more crudely using corrugated tin for fender flares.(like sections of culverts.)
Cut the front frame rails off at the angle of the bottom lip of the bumper. Sand the bumper brackets clean, cut some plates out of scrap and drill it for what bolt holes are left. Position the bumper where you want it, I'd try to split the difference as much as possible. When it's positioned where you want it weld some flat stock or some sturdy scrap to the bumper bracket and the frame plate. Remove the bumper and use card stock to lay out a planogram for the new brackets. For the rear bumper it may be trickier. I would clean up and cut off the frame rails a couple Inches back and then position the bumper where you want it, tack it up and then use some tape to figure out what kind of angles you want whether it be a short steep angle or whether you want to make a nice long upward slope to blend the two pieces. Then use card stock to template and cut and patch the two together...you can plate over them or remove the sides and bottoms and patch pieces in for a cleaner look. There is no easy way for the rear unfortunealy. Great looking cruiser, I'm jealous...and I know that those flares are a Pretty Penny! Are you going to address the open areas in the front? Cap them and 2 part urethane them? BTW, where in the world did you find DCFC's in good condition?
@aktundra - judging by the chop saw in the background of 1 of your pics, and since you plan a receiver based winch, how about just adding some 2" square box to your framerails on the front, with holes drilled to catch say 2 bolts each side?
I'm going to go out on a limb & guess there's a MIG somewhere on premise, so this all seems within your skill level, right?
Your bumper is only cosmetic since you'll be doing a front receiver below the & would only require a center cutout to pull the winch to take back to the rear receiver.
Out back, it'll be a little more work since the frame is covered with all the parts to make the bumper cosmetics, but again maybe do a full crossmember of 2" box with the holes for all the little OE parts, or just start from scratch as you'll need a swingout for a 44" spare & still room to work a receiver based winch.
I think the majority of your issues will be solved by a single stick of 2" box - even 1/8" wall will work for the front if you don't plan the bumper to either be pulled on or used for a recovery point.
Without Arctic trucks shipping you crazy priced stuff, that seems the best route & you can do it all exactly as you like, not what their design limits you to.
