I have a 1991 fj80 and I just purchased some 33x10.50 x 15 bfg all terrains for it. right now its stock and has 31x10.50x15 tires on it. was planning on putting the ome stock height springs under it. I already have the ome shocks and steering damper under it. My big question is would it be wise to re gear it before I put the tires on? how many of you guys are running 33x10.50 15s with stock gears?
You're going to get a lot of responses from guys saying "don't bother" because most of us have the 1fz and really don't feel the difference. But since you have the 3fe, I think you'd get a lot more bang out of re-gearing. But to answer your question more directly, should you re-gear before you put the tires on? I say no. Get the tires on and see how you like it, then re-gear afterwards if you feel like you've lost some pep.
I know. I am one of the few that actively looked for a 3fe 80 because I love the engine even if it is underpowered (more to do with the dang a440f transmission though). thats not a bad idea. where would you get lower transfer case gears. I kinda want to rebuild that anyway at some point. t
There are a couple of good vendors on here that offer them, so just work with them. @OTRAMM and @cruiseroutfit comes to mind. Both are very solid and helpful businesses.
I agree with just put the tires on first and see how it feels.
But I do think if you put 4.56 or 4.88s in it you would be glad you did.
I had 33s on my truck when I re-geared it with 4.88s and it was flat out aggressive lol
The t-case regear may also be a good solution, but I have no experience with that.
I'll second the 10% underdrive in the t-case. It will feel like 4.56's at a fraction of the cost and easier/quicker install. $505 gets you the kit @ Cruiser Outfitters. Gear charts and info here on Mud: YWST: Low Range T-Case Gear Sets for the 1980-2007 Cruisers
I have a 1991 FJ80 with OME stock height springs, and I switched a couple months ago from worn out 31s to 33x10.50R15 BFG all terrains. De-smogged with a fresh ignition but otherwise stock including factory exhaust.
I found there to be a slight decrease in performance and MPG. Nothing noteworthy in town, on the highway it's more noticeable. It's relatively hilly where I live, none of the hills are big but you are constantly going up and down them. I average around 65mph on the highway, and downshifts to 3rd have become more frequent (I also have a front bullbar, big spotlights and a low profile roof rack to add to the drag).
I find when the TC locks up in OD at light throttle now it knocks the rpm down a bit too low (~1600rpm) and sometimes I'll lose speed and it'll drop back out of lockup, so often I'll consciously let it rev out in 3rd more before I let it shift to avoid this.
In town MPG average with the 31s was around 12.5-13, 15-16 on the highway. Sitting on 11-12 town, 13-14 highway now with 33s.
I'd put em on and then see what you think, it's by no means unbearable.
That said, I will be doing something about my gearing.
