Ramathorn15's LX470 build
I think those KISS drawers look pretty slick. I was kind of on the list but pulled my name due to lack of fun money. I don't know that it would work out but I'm planning to be up in Oregon over Christmas and would love to pick up a set and skip shipping. I'm keeping my eyes on them while trying to sock away some money.
I built my trailer March of 2015. I like it well enough for what it is but know its not the end all be all. (Build album here...)If I could do it again I'd worry less about track width (I was trying to match my JK) and make the interior dimensions at least 48" so I could haul a sheet of 4x8 plywood laying down and I'd make it lighter by using smaller (and thinner) tube for the front and side decks but use thicker sheet for the bottom of the tub.
Thats a sweet trailer! I don't know if I feel comfortable enough tackling a project of that size though. I'll probably look at buying a used one eventually. I like the idea of having the bars raise for the annex then come back down for travel to keep the COG lower.
BTW, the fairing was to help with mileage and drag. I can really feel the tent up there when cruising on the highway with any sort of headwind. I also lost about 2mpg.
Curious about your attic/dog net, looks cleaner than my Raingler setup....more pics of the support, please, and where'd you pick up the cargo net in the perfect size?
Thanks!
Thanks you for the compliment. I actually made the entire thing from scratch. I bought 1" webbing off amazon and used 4 buckles from old harbor freight lashing straps. Then got some rings from Lowe's for the lower mounting point. The hard part about the 100 is there are no side mounting points. My old 4th gen 4runner had hooks on the sides where the rear seats latched to when unfolded. The 100 doesn't have anything like that so I had to do the lower mounts on my drawers.
I bet that webbing was time consuming. I did mine for my Jeep and it took forever. Turned out good but since I had never used a sewing machine before that it took awhile to get the hang of it to do it quickly. Yours looks really good though.
I'm getting close to finalizing my switch panel and wiring for multiple accessories. Not sure exactly what I'm going to power, but I have 5 options.
I took a stab at creating a wiring schematic (never done anything like it before). Im 100% certain it's not totally accurate but I can understand it haha.
Here's a pic of why you never leave a 520 peice electrical connector set open and on the ground
It just dawned on me that my schematic lacks a power wire from the battery to the fuse box. Plus, it's missing a lot of grounds but the crappy app I used to draw it wouldn't let me to simple grounds
Shouldn't need grounds going to your switches. Also, you might consider putting the diode on the switch side of the relays, so you aren't putting too much current through them. Wire it so the Roof Lights switch energizes both RY2 and RY1, whereas Reverse Lights switch only energizes RY1. I think that's what you were intending.
Also, when you wire power to your fuse box, if it's a long run, i.e. not right next to the battery, make sure to put a fuse close to the battery. Remember, fuses protect the circuit (wire) in case of over current. Just picture your power cable shorting to chassis (due to any type of damage) and the amount of current that would be running through that cable. Cable will quickly overheat and potentially catch fire, etc.
Awesome recommendation on the diode. I don't know why I didn't catch that. As for the switches, they need grounds for the LED indicators. The fuse box is right next to the battery and has a fuse built in as well.
Gotcha, makes sense! My fuse box is right next to my battery as well, looks like you are good to go!
I finally got some extra photos.
This was the original Lexus Link overhead console. I believe in other/older models, this is a sunglass holder. I pulled the buttons for the lexus link, taped it up to keep from shorting and stuffed it in the overhead console. You have to keep the buttons/board plugged in or you will get an announcement saying to visit a dealer each time you start the vehicle.
Next I had to get through the firewall to run all the wires. I got some help with this from @savirc and @Brian Waag (Thanks guys!)
The threaded bolt was used as one of two mounting locations for the variable steering computer. I was hesitant about losing it at first but decided there was no other way. I used pliars to pull off the stud which created a small hole in the firewall. I then used a stepbit to get the hole to 1-1/4" for the daystar boot I purchased off of amazon.
I had to cut the same hole in the bracket for the computer. It worked out well.
Next came running all the wires. I had to take apart a lot of the interior to do this. I had to remove the sun visor, overhead console, driver seatbelt, A-pillar lining, both grab handles, and the B-pillar trim on the driver side.
From the overhead console, I ran 5 wires from the 5 switches. The power for the switches came from the map light power wire and the ground was a random bolt for the sunroof motor.
Then ran the wires down the A-pillar
After replacing the overhead console with the new switches
Then I had to run the wires through the firewall. I wanted to have all the wires ran through using the mesh covering. So coming through the firewall are 5 wires from the switches, 1-12 gauge wire for the roof lights, and 1-16 gauge wire for the rear lights.
Then I had to wire up some relays. I bought 4 waterproof relays/harnesses. I couldn't find a good spot to screw them so I used zipties to strap them near the battery. I like it since I can easily remove them and add more relays later.
Here are the crapton of connectors for the relays. I had to use a diode for the switch wire for the roof lights and rear lights (see crappy schematic above).
Then i ran the wiring to the bluesea fusebox. Again, I had a hard time finding a place I liked to mount it. I found the distribution box form the positive terminal fit it perfectly. I used a couple metal style zip ties to strap the fuse box to the distribution box. Its super secure. I also needed some heavy gauge wire so I bought a cheap ($24) amp wiring kit from walmart and used the 8 gauge positive and negative wires and inline fuse.
Next step was to run the 12 guage and 16 gauge wires to the roof. I ran them with switch wires up the A-pillar then along the roof under the headliner. I then had to feed them through one of the unused roof rack bolt holes. I also ran my wire for the RTT power and awning power. It was super tight. All and all, I got 1-12 gauge, 1- 16 gauge, and 2-18 gauge wires through the bolt hole. Theres no way you could get more through.
Next I mounted up the 6 lights on the roof. Here comes my biggest complaint about my Gamaviti rack. The little bracket holes I had added to the expo bars where I bolted the lights was kind of ridiculous. Its impossible to get any tool on the backside because of how close the hole is to the bars. I ended up having to hold the backside bolt with a pair of pliars then twist the lights/bolt until it got tight. In doing that, I pulled off a bunch of powdercoating, which brings me to my second complaint. My rack is rusting all over because of how bad the powdercoating is. Its beginning to rust in the crevices where the mounting platform meets the bars. It scrapes off with a fingernail too. I would probably think twice about having them powdercoat it if I still lived in the NE.
I also just mounted up the free LED lightbar I got from Gamaviti at HIH6 (Thanks Tim!)
A nice added bonus that I didn't expect. Since I wired the switches to the map lights, The switch panel is active when I unlock the doors and doesn't shut off until a bout 20 seconds after locking the door. What that means is i can leave the roof lights on and when I lock the doors with the remote, they will auto shut off after 20 seconds. Then when I come back and unlock the doors with the remote, the lights kick back on.
This was a tough install. Took a long time to complete all the wiring. I would guess at least 24 hours of working. Let me know if anyone has questions.
I really like that you used the Lexus Link headliner panel. I had looked at that when I was trying to figure out where to mount my ham radio face plate but mounted it elsewhere. I guess this is another mod you've done I need to replicate.
Any comments on those switches lighting up the cab while driving at night? On a previous vehicle the brights icon on the dash was super duper bright and drove me nuts. I'd probably want a way to dim the switches or be able to turn the passive lighting off on them for day to day use.
Thanks for posting this up.
The always on led's aren't bad. They aren't bright enough bother me except for when they catch the corner of my eye and make me think the police are in my mirror.
They honestly aren't too bright when on too. I was worried about being blinded but they're good. You could easily disable the always on LED too by just not powering it.
Figured I'd add a video demonstrating the perk of wiring my switches into the map lights. I'm not sure about the older 100's, but mine kicks all then map lights off, even if you accidently leave one on. So now, if I want, I can turn all the lights on and when I lock the car, they all turn off. When I come back and unlock, they all turn back on.
This was not intentional, but I love the added perk. I initially meant to just wire them into a source that triggers with the ignition.
I can't decide! Should I do it?!?! I hate, hate, hate the idea of cutting into my fender but like the idea of a snorkel. Help reassure or dissuade me!
