- Joined
- Apr 9, 2013
- Threads
- 236
- Messages
- 2,160
Hey Mudders,
I'm about to replace the original radiator in my rig as PM with a Koyo A1918, and I have a few questions for y'all:
Thanks!
Russ
- What's up with the foam? My radiator did not come with replacement foam to go between the radiator and fan shroud, and my original foam is pretty beat up. Thoughts?
- What size (ID) are the two ATF hoses going to the bottom of the radiator, and to the OEM trans cooler in front of the radiator? I should replace them, too, right?
- Another post said this: "You will need a 1/4" 12mm deep well socket (6pt), 1/4" swivel and 8" extension to remove/replace the passenger side hidden radiator bolt." Is that right? Why does it matter if the socket is 1/4" drive or 3/8" drive? I have a 12mm deep well socket, but I'm sure it's 3/8" inch drive.
Thanks!
Russ
