A) Remove the number one spark plug
B) With a fancy 'tactile' flashlight look inside the spark plug hole
C) Turn the crank nut & watch #1 piston rise to the top. Have someone else turn the crank...or if you have the correct size socket, you can turn it and still watch #1 piston
D) As the piston rises to the top, plug #1 hole with your thumb. When you feel pressure, you are on the compression stroke.
E) Stop turning the crank, continue to watch the #1 hole. When you SLOWLY again turn the crank AND the piston no longer moves in either direction...you are then @ TDC on the compression stroke.
Ah yes, good call. I did not catch that his rocker arms were removed in his post #5.It will have compression on every stroke without the rocker arms.
