Question on this TRE kit
CenTXFJ60
Spring Branch TX (Hill Country)
Putting my sons front end back together and noticed these two outer TRE's don't have grease fittings. The passenger one has grease in it but the drivers side does not seem to have any. I understand I can remove the bolt, add a fitting and then grease it, but my question is this common? The other two pieces have fittings already. Any thoughts or feedback is appreciated. Thanks, Jim
Nice new brake disk :cheers:, I have the same and I have a box with zercs so no problem to replace or use the old one, maybe it is better with a flat bolt to prevent damage?
The bolt is a bit loose if that is what you noticed, don't know if that is a flaw or purpose? It must handle a pressure wash.
They are pre filled and FSM says to move them around a bit and then install (and fill till they blow up a bit) but they don't mention to grease the TIE od, only the RELAY rod.:hmm::hillbilly::wrench:
Bummer if it broke (nipple?) the rubber&spring seal can relieve excess pressure, maybe reuse an old seal for a test drive if it is torn? It seems easier to remove/split again when not driven.
file.php
torque settings:
file.php
file.php
file.php
