I have a new dash pad from fj40dash.com and I purchased a dash pad light off of eBay.
Does the light install under the pad and attach to the metal strip that goes inside the pad
Or,
Light attached to the underside of the pad (after I cut a hole in the pad for the housing to go I to)
Thanks
FYI - being you have the dash pad light in hand, if you haven't already done this, install an LED light in it. Here is what my dash looks like at night, not over-powering. I think I used these > click here <.
May also want to look at this LED light some have used.
Dash Pad (1): Bulb works great. Plenty of room in the housing
DE3022 CAN Bus LED Bulb - 18 SMD LED Festoon - 31mm - 90 Lumens -
