I have the Focal Sub 5km fitted into the OEM box. It fits without modifying the box. I 3d printed a bracket to mount it to the existing mounting holes. It’s an awesome little sub, not cheap tho
David, thank you tons for these photos. I am not 100% familiar with 98-2000 setups, so I will ask another question. Is this your setup?
- 1998 – 2000
- Head unit: AM/FM/Cassette/CD with 6-disc in-dash changer,
- Speakers: 7 (front doors have 1″ tweeter and 6.5″ woofer, rear doors 6.5″ full range, Subwoofer has one 6″ driver in custom cabinet.
- Amplifier: 250 watts (maximum output)
- Optional Nakamichi 280 watt System (2000MY)
PS. I still have those Illusion Audio C6s, just listed them on ebay today.
My man! I do not think that I will expand my inventory anytime soon due to upcoming divorce and a chicken farm purchase (my fingers are crossed). 5KM is a nicety, not a necessity. You can do a pre-loaded enclosure with a shallow sub, WavTech is the current champ in that department, check out the link to see how little of a space it takes. Many options.Thanks! That is what I have with the Nakamichi system.
I found your ebay listing. What would you recommend for tweeters and rear doors. I see the Focal 5KM is a recommended sub. I am wanting to do it all: head unit, 5 channel amp, tweeters, door speakers, and rear sub. I have done a full audio swap in a Tacoma before from a kit put together by the Crutchrot people. I just finished sound deadening/absorption project: butyl, CCF, MLV, Thinsulate.
Not in a hurry so can wait for other products to become available on your site and can order all at once. Thanks!
audiointensity.com
I remember now! My man! Silly question, can you go full tilt with OEM box in place? I am one of those degenerates that likes wants to be able to extract component's full capability if need be.I have the Focal Sub 5km fitted into the OEM box. It fits without modifying the box. I 3d printed a bracket to mount it to the existing mounting holes. It’s an awesome little sub, not cheap tho
@rbrave i think you called it, that my non-stealth idea for the rear of my LC would take hundreds of hours… you were right. Well, it is done. It took many, many hours, and it looks soooooooo, ooooooooo bad. Just working vinyl, even expensive 4- way stretch, over the convex and concave of the rear wheel arch trim pieces was impossible. To make matters worse, we decided not to stick in the house we were in until spring, and moved out in Nov., so I lost my garage space earlier than expected, so it needed to be done, not perfect. It is so bad. For the first time ever, I have resigned to pay someone in the spring to help design and build it out right.
I don’t think it looks THAT bad! A little like you used human skin as the covering, but I wouldn’t have expected anyone to be all that experienced with that material@rbrave i think you called it, that my non-stealth idea for the rear of my LC would take hundreds of hours… you were right. Well, it is done. It took many, many hours, and it looks soooooooo, ooooooooo bad. Just working vinyl, even expensive 4- way stretch, over the convex and concave of the rear wheel arch trim pieces was impossible. To make matters worse, we decided not to stick in the house we were in until spring, and moved out in Nov., so I lost my garage space earlier than expected, so it needed to be done, not perfect. It is so bad. For the first time ever, I have resigned to pay someone in the spring to help design and build it out right.
What I knew, but didn’t navigate well was that I was taking all the utility out of my utility vehicle. The sub can come out, so it is not that… it is that I do not have room for jack, tools, tie-downs, etc. I think the 15”sub is just too big. Need to go smaller, and thoughtfully think how I can have the rest how I want it.
That all said, it pounds. Still not tuned. Way more bass than I need. SI 15 and SI 1500.1 running it. I did tons of damping when I first got the truck, but this year I added to it, and did a lot of sound absorption. It really does not rattle much, and is super quiet riding. Not sure I’d do it again as it was a ton of work and hours, and getting trim back on was hard… but I can enjoy it now.
To be continued…
So doing more research...looks like those Hertz are very highly regarded, but will the 100 door fit a 3" deep speaker? The tweeters are 1.19" deep; any chance these fit in the factory location?Hey crew,
Ive been following along off and on for months and have been doing the intel necessary to get the audio in my LC right the first time without messing with the wrong equipment.
I have come across a Moscani One 60.8 DSP; Hertz Legend ML 1800.3 7" Woofers & 280.3 tweeters from an old client looking to sell. The amp is used but the speakers are new. What can yall tell me about them? They all look to be pretty damn solid, but not sure if the 7" will fit in our doors?
Also, with the amp being 8ch; does that mean i can bridge the front stage with 4 ch, add a pair of standard speakers to the rear and have 1-2 ch left for sub? I don't want to do anything that won't fit in the factory location.
Thanks a bunch!
Thank you for the reply! I'm going to see what kind of deal I can get on these before I get to excited, but will definitely hit you up if/when that happens.Hi! OEM tweeter location would host a small tweeter comfortably without milling it out. If you were to mill it out some, maybe a 22mm unit will go in there. Not to mention, that opening is super narrow and it limit the tweeter. 280.3s are at their best when they have room to breathe. Buy the pods in the link, that is the most non-intrusive way to deploy 280s without modification, pillars come off via two phillps screws. This is the best route unless you want some permanent, like fiberglassed units in the A-Pillars.
As far as the midbass goes, my Esotar650s are only a handful of millimeters shorter than the Mille. I have plenty of space in reserve so you should be ok. I can make you an adaptor for it.
Most people try to get the parts you hear “directionally” up as high as they can to their ears - which is why you see people mounting tweeters and mids on the a-pillars or at least sail panel, whereas the speaker carrying lower frequencies stays in the footwell area. There are lots of mounting options for tweeters, but they will likely look like you put non-stock ones in unless you really try to make them blend in.I read most of the audio guys here are not FJ40 drivers…. But, you all have some amazing knowledgeable information about audio systems these days so I have a question
What kind of speakers would be best to use in my FJ40 doors. I’m guessing size and depth are important considerations. I have a simple am/fm/bluetooth , nothing fancy. Would be nice to have something playing in the drone sounds of the cab at 60mph
Hi! I haven't done any audio related stuff on 40s but I have detailed a lot of them, therefore, I am fairly familiar with their interior nomenclature. Unless you are shooting for a hardcore SQ setup, a simple coaxial 3 or 2 way set up would be great. If you don't have anything in place to host speakers already, SOR makes a decent mounting pod. Lastly, I would shoot for a marine rated speaker since 40s are not scared of water coming in.I read most of the audio guys here are not FJ40 drivers…. But, you all have some amazing knowledgeable information about audio systems these days so I have a question
Even though I could not get my PICO to work in the Audi, I still went ahead and tuned it just in case a miracle happened. Software is very easy to navigate, Perplexity could map out what settings you need to address for your particular setup. However, you need a measuring mic like a cheapie MiniDSP units.Thank you for the reply! I'm going to see what kind of deal I can get on these before I get to excited, but will definitely hit you up if/when that happens.
Any input on that particular Mosconi? Or have you heard quirky things about its controls?
