ps conversion update
sittin on the couch in UT
its coming along, just hope the landlord doesnt catch me. check it out. :cheers:
I like the way you tubed/sleeved the front x-member, did you do the same on the frame horn where the gearbox bolts through?
Ed
i might, i havent got that far i will get that done tonight, i got the idea from kurt at cruiser outfitters, thanks kurt.
depends who you ask i guess:) my wife thinks so, ha ha.
Everyone I know has either tubed it(the frame horn) from git-go or has gone back and done it. Without the tubes there is enough flex or crush that the bolts back off. Hell you're there with the right stuff and at the right time, do it!
Nice job, clean. And good pics, too.
Ed
Looks good. I didn't have a cutting torch or a hole saw that big when I cut the cross member hole on my 73. Stayed with the 3" hole. I still have to finish welding up my plates. Got side tracked changing the engine mounts. If you use the Bob Firestine mounts (great mounts) you will find that the engine sets lower than with the old Downey saddle mount. On my rig, the lower engine caused the fan to hit the lower rad hose. I am using the stock rad. I played with the rad trying to offset it to one side or by trying to lower it. When I lowered it the rad was in the way of the steering shaft. When I moved it sideways, too much of the rad was uncovered by the fan. I finally decided to go with an electric fan. If you use Bob's mounts, you will probably also have to remove the exhaust in order to get the mounts on the frame. I used the Downey ps kit (purchased from Marks Offroad ) . The kit was pretty complete. I have an 86 sbc and am using the ps pump brackets that mount to the head. :beer:
Ed
The tube I was referring to was the one through the crossmember. Most horns I've seen have been "boxed" like you mentioned. However, mine has neigher the cross member tubed or the horn boxed. PO did the conversion. Seems to hold up ok, I'll keep an eye on the bolts.
Here's some pics. Even though it's not completely boxed it's a pretty HD plate welded in. The upper bolts run throught the plate and into the frame while the lower are outside the frame (I guess that's common).
CamCruiser, nice work, the sleeved crossmember was good call, I imagine it beefed up the cross memeber in that area substantially; keep us posted on your progress.
The idea fool.... you got the parts ;):D
yes it was my idea... more pics on monday, i am finishing it tonight. its awesome
Finally got pics to pull up.
What u joint are you using at the steering box?
What about at the firewall?
Oh, it looks good. I like the idea of sleeving the crossmember.
J.R.
i got all the parts from kurt, previously chimed in, both the same at each end. i will post pics on monday, i need to weld it all tonight and take her for a spin. vrooooomm
