Project: Stock Front Bumper With Integrated Winch II
CruiseOrlando
Conveniently Enhanced
Orlando, FL
For those of you who think you've seen this before, you have, and that's where I got the idea from:
https://forum.ih8mud.com/80-series-tech/370693-project-stock-front-bumper-integrated-winch.html
Of course there's always a bit of this-and-that when it comes to these things, so I wanted to share my experience in the hopes that it helps someone else in the future.
I bought the Badland 9000# winch from Harbor Freight. Since I don't plan on using this a whole lot, I didn't want to spend $1000+ on a nice one. I found this one on sale, then somehow was able to double up on the 20% off coupon to get the price down a whopping $209. Don't ask me how, I'm not quite sure myself.
I also got the channel mount from them ( Universal Channel Winch Mount ). This took about 2 months to get since it was backordered. But I wasn't in a big hurry anyway so I didn't mind waiting.
So far I was in for about $310 after shipping and all, which I was pretty happy with. Upon opening the box, everything was packed nicely and it looked pretty good.
When I first started finally putting things together, I didn't realize how much cutting was really involved. I had to really trim down the channel mount quite a bit, and none of the mounting holes lined up (except for the ones for the winch itself to the plate). I used a few metal cut-off wheels - I got one for my skill saw, the other for my angle grinder. They both came in handy for different cuts - the saw couldn't get into some places that the angle grinder took care of (and the skill saw wasn't a good choice for the bumper cutting).
After a few cuts, I did my first test-fit on the truck:
That seemed to be ok for the first test. So I put the winch in place, and make sure everything was accessible.
This started problem #1 - I couldn't turn the clutch handle to the fully engaged position! It was hitting the tranny radiator...
In trying to come up with various ideas, I posted https://forum.ih8mud.com/80-series-tech/558590-need-help-mounting-winch.html to gather thoughts on what I might be able to do, and was told that "clocking" the winch would probably do what I wanted to do. After a little fumbling around, I finally figured out how to do it, and moved the handle position forward a bit.
In trying out a few more test fits (and after cutting the bumper for the first time), it looked like I would be able to make it work if I took out the lower 'air vent' covers in the bumper and reached in there to move the clutch handle.
I put the fairlead on, and figured out that was going to be a real pain in the a... when it came to final assembly (the bolts are short, and due to the nature of this project, the entire assembly, bumper and all, would have to be on before I could put the fairlead on. This would prove to be a slight challenge later)
Then I test-fit with the bumper to see where I was.
This was the end of my available time for the first weekend, and a few things were apparent. One, getting the bumper on was going to be a real pain in the butt. Because I didn't want to fully compromise the bumper integrity, I wanted to leave some steel along the bottom edge. This wasn't exactly cooperative with the channel mount, which was protruding a bit beyond this.
Second was the tie-downs, which would need some kind of spacer to go back on due to the 1/4" plate of the channel mount that was now in the way. More on that later.
The third problem was the solenoid box. I wasn't sure where I was going to mount that, but I'd run out of time anyway so I forgot about it for a week or so.
This weekend I started on the solenoid box, and after dinking around with various locations, I played around with putting it "where it belongs" on top of the winch. A bit of pushing, prodding and cussing developed a postion that I was relieved would work well - but only left about 1/2" of clearance to the body! But that's ok - I plan on a 1" body lift pretty soon anyway and that should give me a little more breathing room right there.
All of the power cables would route well and work without issue, as well from here:
The tie-down hooks (or "recovery point" as some people call it) were another problem, but a few fender washers fixed that. I did have to source a few extra bolts (1.25 x 12 if anyone is interested in knowing) that a local hardware store carried (10.2's, I think?).
The channel plate was mounting up to the forward two holes on the frame rails, and you can't keep these tie-down points that far forward if you hope to bolt the bumper back on. So that's why it had to sit back in its original position.
After a few more trims, some rustolum on the exposed surfaces and a few good whacks with my mallet, everything finally came together:
A little bit of wishful thinking - actually I just put the truck in N to try and wind the rope properly...
And a few close-ups of the job after everything was said and done:
I'd say this is a :banana: :banana: project. You should probably have 2 people, too... probably would have saved a few moments of frustration on my part.
Great job, really looks tight.
Old thread, I know...
... but doing a setup like this, with the stock bumper and the hidden integrated winch... do you need to upgrade the front springs? Already running new OEM Landcruiser springs with Bilstein's.
I think it depends on the condition of your springs. If they're old and tired, they might not react well to the added weight. Mine were ok until I added a heavy bumper on the front...
Is it possible to mount the winch upside down so that the roller fairlead isn't hanging so low? Does that introduce the winch to too much exposure below?
Interesting thought. I guess you could mount it upside down, but it would expose the winch to a lot of elements. I think it would technically function the same... you'd have to clock it a lot more as well. I can't recall ever seeing that done before, however.
The other issue I can see is that you'd be cutting into the bumper right between the 'vents' or whatever they are. That might really take a lot of structural support out of it.
My opinion of the front bumper is that it has the structural support of 1 ply dunny paper even when 'stock' :)
cheers,
george.
I just did this using harbor freights plate.I had to enlarge two existing holes and used the bolt from one of the tie down points to mark where I had to drill for the other two.i threaded the bolt from inside frame raildown into the plate the tie down bolts are self taping type and made perfect marks on the plate using a center punch holes aligned perfectly.Now I have to figure out how and where to cut my bumper
Measure twice, cut once!
Orlando did you have to use any type of spacer on the fairlead to get it to stick out far enough, or did you cut the hole large enough to clear the whole fairlead.I was too tired from lugging that beast up and down off my Jack to even get into bumper placement any tips eh.very good write up by the way.I had doubters that said it couldn't be done and I just showed them your write up.haters gonna hate.but this article shuts em down
LOL.
No problems with the fairlead. That was using the included mounting hardware w/the HF winch.
Cu
Project: Stock Front Bumper with Integrated Winch
In trying to come up with various ideas, I posted Need help - mounting winch to gather thoughts on what I might be able to do, and was told that "clocking" the winch would probably do what I wanted to do. After a little fumbling around, I finally figured out how to do it, and moved the handle position forward a bit.
At around 3 years later, how is this winch holding up. Im in the process of doing the same setup,
Good job on these projects, guys. I like solutions that don't break the bank. Not everyone on this board (not me, for sure) has deep pockets and a 911 and an M3 in addition to their 80.
Bicycleagent003, to show you that it can be done on a budget here are a few photos of my Craigs list winch that i bought for only 200 bucks. It's a made in the USA Ramsey Pro 9000, i installed it so it would have that hidden factory look. Here's a link with more photos to my winch install. Factory bumper hidden winch install
img_0030-jpg.1403905
img_0029-jpg.1403902
