Build Project Patina-November 1968 FJ-40
Cam is bored and wants another carport project.
A 5.3 in a 40 would almost be cheating it would be so easy though after his last 2 jobs
Hey girl .......
Did you fix the knock? It's hard to tell when you're running an open header.
I slapped a Cherry Bomb on Patina and fired it up.
The engine knock is terrible. The harmonic balancer has quite a wobble too.
Julie was near and walked up and said said "I'm no expert, but that
doesnt sound right
Worked on this pos all day.
Added some headlights.
Took out the Ebrake and Tcase handles and cleaned up a few wires. It was pretty good for a few hours until I decided to start replacing window weatherstripping on the doors.
I broke the glass in the window and spent 3 hours replacing the gasket on one vent window to find that there is zero chance it will close with the new gasket.
New rubber and felt but a broken window getting it there
So basically I got nothing done but ruining a door.
This gasket was like concrete in the channel.
New gasket was a total pita and then the window didn't fit.
Fxxx this POS.
On those gaskets use a heat gun to soften them prior to removal. Can also use them to warm up the new ones so that they fit in properly.
