Build Project Patina-November 1968 FJ-40
Awesome. I'm way to far gone in this thing in another direction on all your suggestions but it should be a lot of help to someone.
JimC. You've always been and always will be the man. You got my 84 running great on 2009 and it still is to this day.
JimC. You've always been and always will be the man...
Is it a mere coincidence that his initials are J.C.? I think not.
Let us pray.
Jeebus, you guys talk a lot but don't say much. 19 pages and the truck has never run? :flipoff2:
Having plowed through most of this thread, here's the answers:
The mystery electric box on the firewall is an ancient hydro electric trailer brake controller. It was teed into a hydraulic brake line and a small piston inside slid the lever sideways and drag the contactor up & down the resistor coil. Throw it in the weeds, then throw rocks after it.
To put the 2F in the F chassis, use the F engine mounts drilled to M12, or use 75-80 2F mounts. Don't go hacking up the 40 frame to put 60 ears in it... oops, too late.
At the back, same deal. Use a 74-80 4speed bell with FJ40 mounts bolted to the side. Unlike the front, these are dimensionally identical over the years, so the 68 rear ears will bolt to a 78 BH, but have the bracketry for the driver-side slave. 55 is different from 40.
To make the engine bolt-in, dress it as an F. Use the nifty 68 manifold & adapter & 1bbl carb & air cleaner. that keeps the throttle, choke, hand throttle all stock & easy. Use a header if you got it, but be aware that clearancing of the header tubes to intake manifold will be necessary because the 68-69 manifold is very close to the head. A combination of dimpling the header tubes w/ a ballpeen and some diegrinder action on the intake will get it done. To clearance the intake & header for the M12 2F fasteners, bolt the pair to a scrap F head using all bolts (no studs). Run a 3/8, then 7/16 then 1/2" drill bit into the mounting holes, one at a time, removing & replacing fasteners as the drill is moved from hole to hole. Follow with a spotface bit to get all the holes level. Boom, intake/exhaust done, just need to bootyfab an exhaust system.
Use any 74-78 fuel pump so the hardline to carb will connect to pump, and it won't have the later return hose to cap off, and it's got eleventeen little PH#2 screws on it which looks correct.
On the cooling, don't use the giant aircon FJ60 lower rad pipe. Use the 68 pipe and 68-76 lower rad hoses. For an upper hose, the 81- hose to fit the t-stat housing is NLA. Force a 68-78 hose in there and keep your eyes out for a 79-80 upper stat housing, they use a standard 90* rad hose.
Remove temp sender & holder from the 68 engine & thread into 81 engine to work with 68 gage.
To keep ignition simple, use the vac advance 1968 dissy & clamp. If changing to a 2F dissy, be sure to use the thinner 2F clamp so it doesn't hold the dissy up off the block.
That's all I got for now, HTH somebody...
BANG!!!!
Another day of work going on this project with no one touching it......
I heard from @beno today. Looks like my parts will ship tomorrow for me to start screwing stuff on the truck this weekend.
I stopped by Perfomance today in Memphis and they don't sell direct but they told me what I needed.
DUI p/n's 80820BK...black distributor C9079BK black wires and they suggest Autolite Premium plugs gapped at 50.
Ordered $450
@cruiseroutfit sent my most recent order. Kurt lost a family member this week but the business rolls on. Thank you and your crew.
ACC is going to weld up the holes in the bottom of the manifold where the crack was, blast and powdercoat it.
My brake lines landed today.
My @Trollhole carb hit last week.
Lots to do.
I'm over ten grand on this thing at this point with a BIG Beno order about to hit.
Needed to buy:
Pay for tranny hump repair and patches from @metalshaper
Driveshafts
Did the drive shaft lengths change or a flange bolt pattern issue?
Both. I can use my slip yoke end on the 3rds and I have both patterns of SplitCase. The ones on it are the rectangular ones.
Georg sent me the round flanges to redrill but my driveshafts won't fit flush on them due to the centering hole on the flange.
This is what I need. I'd love to have some shads from the center row there to match to my slip yoke.
Needs a pair of 74-84 FJ40 D-shafts to get correct lengths and t-case pattern.
For diffs, either swap diff yokes on from 74-77 diffs, or slip '68 ends into later tubes.
Thanks @FJ40Jim. That's the plan.
Do you think those you mention will allow me not to have to do any cutting/retubing?
Do I simply need to find a front and rear driveshaft from those model years amd slip my yokes on?
I thought the SplitCase was longer. Good to know if not. If it's just 2" or so there is plenty of slip to handle that.
Looks like Lash has a rear.
Looking for a front Dshaft. No slip. 74-84 FJ40
Hell, I need to did in my stash....I could have one. I got something in there.
We need to do a Swap Meet at @dnp place one weekend.
I have seen pics of every single historical marker in Mississippi. This thread needs more pics. Feel free to place-hold with pics of Julie until you can get some Patina pics in here.
Come on.....Cool now, and if later, JRob is gonna hook me up to keep it warm
