Yup. Would work well.
Cool.
Lots to do before Logan's run...hopefully it will be done done now.
you and me both
Know that defeated feeling? Well, fill up a freshly rebuilt and resealed transmission to literally watch fresh gear oil leak from BOTH pto side covers. f*** me, lol. I even waited a week for the anerobic sealer to cure.
I think the covers aren’t perfectly flat and did have some rust pitting. Hoping a pair of new billet covers from Novak will solve it.
Now I need to clean out a drain pan to catch the special sta-lube gear oil to reuse vs tossing 0 mile fluid. First world problems for sure...
Isn't there a skid plate that can catch the leak??? That's how I handle my speedo cable leak. Works great until I crest the driveway hill and it empties onto the street. Far easier for my simple mind to drop the skid twice a year to check/fill the fluid than to fix the leak. I mean, I'd have to figure out what a Speedi Sleeve is, what size I'd need, how to do it...ugh.
What Material is the gasket that’s leaking?
The transmission breather is working properly, correct? Wondering if it's plugged somehow, causing case pressure to rise and blow out seals. SM420 vents through the shift hole or through somewhere else?
FWIW, I've never had a leak with Hylomar, but I have with "right stuff". Hylomar is expensive, but my go-to for critical applications, even sealing metal-to-metal surfaces in the drivetrain without issue.
If you're going to pull the retainer out, bring it over to the shop and we'll skim cut the back side to make sure it's perpendicular and flat, as compared to the nose. We probably should have thought of that before![]()
