Build Project Boomerang
ok so scratched my head a bit and decided to pull the lower bolts from the bellhousing. This solved the gap issue completely. The lower bolts that thread from inside the bell were pushing the trans away from the bell creating all the weird gaps. I ran a tap as far in as I could on the drivers side lower bolt hole but it stops about halfway. Holes must be misaligned just enough to cause a issue. Only thing I can think of is to pull the trans and and remove the bellhousing threads so that hole is just a pass through and then the bolt will go straight into the trans threads.
Are the lower holes in the old b/h threaded? I don't think mine are.
I would probably drill out the lower bellhousing holes. I'm not sure you would be able to thread in the lower bolts from the outside.
Picked away at getting the interior installed this weekend. Still have a ways to go
Pulled the trans and drilled out the lower bellhousing bolt holes and then reassembled. Big thanks to @Boston Mangler for helping me heave that thing back in there. Starting to slowly reassemble everything.
Good times man! 💪🏼
Buttoned some more things up and spent a lot of time working on getting the clutch to adjust. Which the new bell I have a little bit of adjustment that I can make to the pivot ball stud. I backed it out a few turns and the fork ended up in a good spot.
I got the battery charged and did a quick back and forth on my driveway. Shifted ok but had a odd whine. I checked tcase fluid and it was pretty low. Today I flushed the trans and tcase and went for another drive. Much better this time and shifting great. I heard the whine a couple of times, at low speed. I think it's the parking drum. I'll need to take a look at it again
Adjusted the drum last night and went for a few more drives. Seems nice and quiet now. Updated to-do list:
Install batwing rear crossmember
Re-work AA clutch slave bracket for better alignment and so the clutch slave can be mounted correctly with the bleeder on top.
Re-work Tcase linkage so that it's farther away from the floor.
went down the rabbit hole of trying to get some music in my FJ40. I just wrapped it up and so far I am pretty happy with the setup. I bought a cheap Alpine media only (bluetooth and USB) to put into my tuffy console
Kick panels from SOR with some Polk Audio 5 1/4's off of Amazon. I wasn't sure how to install these because I couldn't access behind the door frame for the upper bolt. I ended up installing a M6 Rivnut for the top bolt on both sides and a M6 nut and bolt for the lower bolt.
Wrapped all the power and front audio cable in painless brand power braid that I had left over from my Chevelle and then used Pclamps to mount it to the trans tunnel.
I used Magdaddy magnets to help hide the speaker wires in the kickpanel and under the lip of the tub for the rear speakers. They hold pretty well and have a loop for a ziptie
Nice work. The magnets are a great idea
Thanks! I really didn't want any holes or for the wires to be visible. I'm almost done hiding them. I'll post a pic of the finished product. Magdaddy makes all kinds of magnets, I've thought of some other projects I could use them on
I think I finally have all my issues worked out and have logged quite a few miles with the new setup and so far all is good. My last issue was my slave cylinder would eject the piston out of the bore and I went through several before realizing the issue was my fault. I wasn't setting the piston at the bottom of the bore before adjusting the pushrod and TO bearing. So my stroke was ending up at the end of the slave cylinder bore and the piston would shoot out.
Fix was to shove the piston all the way to the bottom of the bore and then adjust the pushrod and TO bearing. Been fine ever since, and I felt dumb is was such a simple thing. Thread for that rabbit hole is here:
I also fixed the AA slave cylinder bracket so the slave mounts with the bleeder up and is more parallel with the clutch fork arm.
Said "F it" and pulled the trigger on a new AX-15...It's a brand new unit that I bought from Quadratec but is a AA transmission. Here's my initial plan:
  1. AX-15
  2. Transmission to Bellhousing adapter This is from NOVAK adapt and will allow me to re-use my existing Corvette bellhousing that I have on the SM420. I will be able to keep my bellhousing to frame mounts as well as my slave cylinder bracket and setup. The AA bellhousing has no provision for frame mounts and I would need to go to a batwing crossmember.
  3. Flywheel/clutch/pressure plate will remain the same one I just installed from AA
  4. Pilot Bearing will need to change to one with a .750 ID. Both NOVAK and AA sell these.
  5. Transmission to Tcase adapter - this piece from AA will allow me to keep my existing Tcase or go Orion later on.
  6. Drive shafts will need to change length since trans is longer and adding 1 more adapter.
  7. Trans tunnel cover will need to be modified.
  8. Tcase shifter linkage will need to be re-worked.
We put an AX15 behind the 235 in my son’s 84’ CJ7 Jeep when he was still in High School (from daily driver to climbing rocks in Moab) we were and are pleased. (Couldn’t afford to build him an Landcruiser!)
