Prinsu 200 Series Rack INSTALLED
My first thought was a footman loop attached to the flat part of a rack but I'm guessing that also wouldn't work with the buckle? That said... you could just remove the footman loop each time you take the bag off.
Can you remove the entire strap from the bag and replace with something that has hardware that's easier to use? Something like an e-track strap would be pretty clean or at that point just use a 1 inch strap with the mounting points that you already have? Perhaps poke around here -- Strapworks - Straps, Webbing, Tie-Downs, Buckles & More - https://www.strapworks.com.
Thanks, the footman loop is the right idea. The bag straps have all buckles sown in and the run in a full-length sleeve, so no easy way to replace for another strap solution. The D-shaped rings for the airline track system is almost there, but the ones I see online in that shape, like the O-ring style, won't fit the buckle to pass through. I might buy another basket kit for the side panels and just run the straps under those like I do in the rear. Just was hoping for something a little cheaper. Thanks for the great suggestions, everyone. I appreciate it!
Finally installed my grab handles & the Baja Designs rock lights. Took close to a month to arrive after I ordered them. Hopefully will get a chance to wire them up in the next few days. I also ordered a "standard" wind fairing to replace mine with the light bar cut out to try to reduce some wind noise....already moved the front bar way back. Anyway, shipping for the $65 wind fairing was $40!!
Anyone know the length of the M8 hex
8m hex bolts, not stainless.
Also, here's some other hardware you might find useful for the Prinsu rack:
1/4"-20 x 2" bolt - fits perfect in the slot. Different sizes available. I used these in combination with the plastic knobs below (and fender washers) to secure my MaxTrax and axe.
Plastic knobs - You'll need to get some 1/4"-20 nuts to drop in. Readily available at HD/Lowes.
Tie Down Rings
T-Slot nuts. I used them for the rings above but plenty left over for other things.
@BigMF and others who recently installed, are the 8m hex bolts provided still NOT stainless? If no, anyone know the length of the provided M8's?
I ordered the rack (waiting for shipping ETA) and looking at upgrading the included hardware to something that isn't going to rust out on me in a few years.
Mine came from Zac, the inventor of the Prinsu rack. I would check with CBI offroad, who bought the design and might have changed the hardware.
HTH
HTH
I called CBI and the guy told me they are definitely not stainless steel. He was unsure of the length that goes into the roof. They don't have install directions posted for the LC 200. They were kind enough to send me a link to an install video, I was a bit surprised to see them using in impact driver to take off the OEM plates from the rack. Must have had far more luck than others here on mud.
Looks like I'll get the rack delivered next week. Once received, I'll measure the M8 bolts and post. I'm definitely using the method(s) everyone here has posted. Great info.
Even after several years CBI hasn't made installation instructions, or a detailed parts list? Weak CBI.
The most critical step is to loosen the factory rack bolts, alternating between each pair on a single foot. A few turns on one, then a few turns on the other, back and forth. Do that and you will not spin the "nut" plate under to roof and all will be fine in the world.
The next most difficult step is to figure out shim placement to your liking, time consuming process. I did approach CBI about this after they purchased Zach's design, without any success.
Refer to the attached pic with torque specs for the rack fasteners (note: this is for OEM hardware which is far better quality than supplied). Most seem to have stopped short of the OEM# for multiple reasons.
Good luck!
Good luck!
Great summary and advice. Thanks
Can anyone confirm that the total height of the Prinsu rack installed on a LC base with stock tires and suspension is < 78"? Of all the rack options, the Prinsu seems to be the lowest profile and I need to stay under 78" in total height for parking garage purposes.
With my shim selection (round spacers and washers) the Prinsu was about 3.5" above the roof in the middle of the rack.
I was able to get mine on yesterday without any issues. I'm pretty impressed with the rack, once everything is together it's very solid. I took it for a short drive only up to about 60 MPH and the wind noise is very minimal even with the sunroof open. I am running the fairing at the lowest setting. I plan to put the RTT and awning on later this week for an upcoming trip. I followed the cabrack instructions and used a huge glob of RTV to seal it to the roof - hopefully it's water tight because it would be a pain to redo!
Ignore the anti-seize on the fairing, I used it on the fasteners and made a mess. The fairing is nicely powder coated.
Great install! What's the overall height of the rack from the roof line? Thinking about this set up in lieu of the ARB Base. Thanks for your input.
Anyone still have their stock LC roof rails/crossbars? Looking to put the roof of the LX to use while I save up for (hopefully) a Prinsu. I'm in Fort Collins, so CO is great, but shipping is fine, too.
Finally got mine installed today. Was very careful during OEM disassembly, but the #2 driver side retention clip was not cooperating. added some marine adhesive to temporarily help keep the yellow tubes in place for the install, but one side still dropped on me and caused me much grief. took a break, cleaned out the permatex in the spacer so I could see, and loosened up the "good" bolt and wiggled it around until I was able to rotate the nut on the clip in place.
I really don't like the spacer setup. Very awkward trying to get the rack aligned and balanced. Made quite the mess with the permatex.
The front runner blocks make much more sense. and I am definitely not a fan of these dumb retention clips.
Here's my partial install, fairing and rest of the cross bars will go on after I apply ceramic coating sometime in the next month.
Good luck!
So after the factory bolts are removed and the carrier is in place, will any force from above (spacer movement while landing out side rails) push the carrier down into the vehicle? The care part is clear on removing factory rails, but what about anything needed to keep them in place during install of Prinsu rails?
here are some pics i took during install. Previous owner had the rear quarter panel painted, and looked like body shop had butchered the rack removal. One of my captive nuts was completely loose, but I was able to work around it.
I'm not sure I fully understand your question, that said, a couple of tips.
Pre-assemble the rack with enough crossbars to give it some rigidity. I used 4x4's blocks on towels to initially set the rack on, then removed them as I set the front or back into position using the supplies spacers for a rough fit.
If I recall, the center feet will touch the roof before the end feet do, so that is the most critical spacing. As I said before, this part is time consuming to get fitted correctly. Weak link on the Prinsu rack for sure.
