Primer for FJ40 fiberglass top
F.E Warren AFB, Wyoming
hi all,
Question: What kind of primer should I use prior to applying single stage paint on this top? I have sanded it down w/ 60grit. Also, what product should I use to seal/repair the rain gutter. Seamseal?
Thanks in advance.
Yea, the PO repainted. Ive got the primer figured out now. The other question is, what is this material that seals the raingutter? Its hard as a rock, and I want to repair it before I paint.
Where the original tops seam sealed? Seems like I remember nothing between, or on the gutter except fiberglass to metal and that is the reason everything leaked down the road. So putting a sealer on the outside may help, but only slows down the problem that's going to happen over time as the top and panels twist and turn. Haven't checked the long term usage, but I put a seam sealer in between the fiberglass and the metal drip rail and the rivets hold everything together. I have a 1978 top down stairs that I looked at today and it had the bead on something trying to keep out the water. Part is there and part is gone. Anyway just my .02 worth on something I have dealt with and was trying to come up with a better solution. Now the seam sealer I used was a roll of black stuff and was sticky one both sides, hollow in the middle, guessing it was some type of seam sealer as the guy doing my top was a body shop person.
SHane
@Captain M - what did you end up using for the primer?
...via IH8MUD app
