Isn't the license plate light supposed to shine down on the plate, not in the eyes of the lucky slob behind you?Finished the plate holder.
Now have to wire it up.
PS - I liked your old top better. The one made out of the old billboard sheet.
Finished installing the full-float axle hubs. Still have to install and bleed the calipers and install the antiwrap bar. But at least it's now under the truck.
Got the rocker assembly all cleaned up. Took forever, the rockers were all seized in place with sludge. Lots of gasoline, a paint brush, and a syringe to clear all the oil pathways and she looks serviceable again.
Next problem. I can't get the damn air rail off the head. I removed all the union nuts. But it is stuck in the lower bolts (that you remove and replace when you desmog). When I crack the lower nuts, it puts torque on the rail, and will break.
I am pretty sure I have to remove the air rail to skim the head.
Try some heat from a small torch. These lines are notoriously easy to break. Patience and a light touch on the wrenches are an asset. Key is to not turn the fitting without the nut that holds the line to it turning. Be sure to get the nuts lossened on the fittings before turning the fittings out.Got the rocker assembly all cleaned up. Took forever, the rockers were all seized in place with sludge. Lots of gasoline, a paint brush, and a syringe to clear all the oil pathways and she looks serviceable again.
...Looks like a great weekend. Wrenching, burgers, drinking, and getting waist deep in some hotwomenwater [coolant].
