A big honking ARB compressor was stuffed into the 40, thanks to the ingenuity of @Jakes40 and @TRFCSUX .
Love it. Good use of space in the bay, and on the cooler side of the 2F.
You've been busy for sure! Be careful with that Ford stuff, it's heavy as you know....I have a fake disk in my neck and a permanently numb right thumb and forearm thanks to my son's 99 250 super duty with the 7.3...we were doing the leaf packs up front to level it back out and yanking those axles and springs around herniated the disk in my neck.I've had a lot going on and my plate has been full of stuff needing my attention, so the land cruiser is having a long sit as i try to knock out a bunch of other projects.
View attachment 3493489 View attachment 3493490
Currently doing a frame swap on the camper hauler 7.3, going to an 06 f350 frame so i'll no longer have leaf spring front and i'll have bigger axles.
View attachment 3493492 View attachment 3493493
Cut a rotting deck and stairs off from my house, its rotting and was posing a danger of ripping the side of our house off. Have to redo seven support beams and a couple other bits. Going to build it a lot smaller than original and try to seal it from the elements unlike the previous owners.
honorable mention to the danger ranger flatbed, putting in work while snappin necks.
View attachment 3493498 View attachment 3493499
I am collecting toyota parts as i find them though, got an 80 series free float for the rear, a 60 front housing, and two 60 front third members with 4.56 gears. One even has an lsd! The housing already has marlin gussets and ruffstuffs soa kit thats turned 10deg for caster, so it ready when ever i get the springs i want! Also found a cyber monday deal where 6 shooter knuckles were over $200 off so i ordered those! I didn't want to turn into one of those members that jumps in an out of being active or just up and vanishes in the wind. I plan on building the bj70, but i got other stuff i have to do first. I'm trying to take it out more, but the radiator has a leak and i need to pull it and fix it soon, also gotta adjust the valves in the 3b.
Eric Jr is looking proud!You've been busy for sure! Be careful with that Ford stuff, it's heavy as you know....I have a fake disk in my neck and a permanently numb right thumb and forearm thanks to my son's 99 250 super duty with the 7.3...we were doing the leaf packs up front to level it back out and yanking those axles and springs around herniated the disk in my neck.
And my same son is Jelly about the Land Cruiser fun, especially the big tire old school 40's, but he's always been a Ford fan and just picked up this beast....1 ton SAS, 460 motor, etc....built by an old Ford mechanic from all Ford part and actually quite well done and still rust free!
And how he had to trailer it home on stock size wheels & tires....the white 250 is what did my neck in...
That's a tall truck.You've been busy for sure! Be careful with that Ford stuff, it's heavy as you know....I have a fake disk in my neck and a permanently numb right thumb and forearm thanks to my son's 99 250 super duty with the 7.3...we were doing the leaf packs up front to level it back out and yanking those axles and springs around herniated the disk in my neck.
Yes it is...does have a 3" body lift that I think he'll pull back off, but the springs are OEM Fords and not really that stiff amazingly enough....riding on 44's now, tires pretty crusty, but hold air. His first truck that he bought when he was 15 (still has but parting out) is a 93 Bronco...had it for 14 years now. Got the 4bbl carb rebuilt and needs new ignition stuff due to a weak spark, but a fun project for him no less...I did tech my boys well on mechanicals!That's a tall truck.
Added another Toyota to the stable for my son - Tacoma. Now he is interested in wheeling….. oh and upgrades
View attachment 3494574View attachment 3494575
Tell him to stay off Tacoma World. It's a cesspool.
Sadly it's not a manual, hard to find especially considering the other criteria on the list.Tell him to stay off Tacoma World. It's a cesspool.
Btw, auto or manual?
That's a lie.. don't you discourage over-moddingwell let him get into it slowly... 35s and all are not needed right away!
Disagree. Sign up and immediately create the following threads:
Which lift do I want?
Largest tire that will fit without cutting bodywork
Suggested oil change interval
Which tire should I get
And the chef's kiss: Which offroad gear will make my truck look special at the mall?
Sit back and watch the hilarity that is sure to follow.
(I troll the turd Gen section pretty hard, since the 1st Gen, Best Gen section isn't super active)
No Taco here, but I have been needing some good entertainment so maybe I'll start lurking there every now and then!This thread is just getting fired up
New Oil Cleanliness
I learned something from the attached video. I was not aware new/unused oil had a contamination level that wasn’t ZERO. The best high flow filters...www.tacomaworld.com
Guy watches YT video about PRE-FILTERING new engine oil and is now considering doing it on a Taco.
Sure, there are stupid threads on every car forum, but what makes TW so special, is how there is no beating-around-the-bush on calling them out as such and then having the shyte show commence immediately thereafter.
I've never owned a VW, but I've seen several references naming VWVortex as a good comp for TW.
forum.ih8mud.com
