Power steering question
I recently had a reputable land cruiser specialist shop recently do a fj60 power steering conversion on my 40. I paid 2800 for it, I believe with labor. After a few months it starting leaking oil bad at the gear box. So I took the truck back and they said they installed a used gearbox and I would have to pay around $700 to get it rebuilt. Did I pay too little? I thought I would get a remanufactured gearbox and have some kind of warranty. I would appreciate any comments. Thank you
Which shop did you go to? What was agreed on before the work started?
I went to Torfab in Everett WA. I don't recall agreeing to putting a used gearbox in or anything stated on the workup. I figured for $2800 I would be getting a remanufactured box and everything would be solid.
Just pull the box off and send it to west texas offroad. About $150 to reseal the box. I've had them do 2 for me. No problems in at least 3 years.
A good strategy is to get another used box, send that to West Texas Offroad and then swap when it comes in. There is also a good power steering gear rebuilder in the Northwest. Forget their name, but I have heard they do really good work.
Seems to me that they stuck it in you and are now trying to twist it. If they installed a used part without your approval or knowledge that sounds like fraud to me.
One good example Iron Pig states a rebuilt is part of their kit right up front. Seems they a pros and make it clear in the start.
$2800 is what Tor quoted me a couple years back for the same conversion.
I decided to save some money and did it myself for half of that.
My gearbox was used and leaks a little too. Looks like I'll be sending it to west texas as well.
$700 to rebuild seems high, I would hope Torfab would give you a better deal than that if they are installing used parts and expecting them to last. I'd recheck all reciepts and speak to Tor again. Seems like a very reasonable and honest guy to me in the few times we've spoken. Good luck!
If doing this, make sure you get the same vintage PS box. there are 2 different bolt patterns, it would only make you feel worse after getting a re-sealed box and going to install it and finding you have the wrong vintage box, and it won't bolt up.
Hard lessons are best learned. I would not give them another dime. I just watched a YouTube video of a guy pulling apart a Toyota box to drill and tap for hyd. assist. Seemed to come apart rather easy with simple tools and minor precautions. If it's leaking it may be as simple as an oring. Do some research and learn to fix and do it yourself. Otherwise, identify exactly which box you have and contact west Texas off-road.
