Power Button
Albertville, Alabama
I searched and didnt find anything that clearly answered my question so here goes.....
I never daily drive with the PWR button engaged, I typically only use it when I need the extra kick in the pants (rpm's) to change lanes, get into traffic and so on....
Has there been any evidence that leaving the PWR engaged all the time wears harder or causes any transmission problems? Keep in mind I'm on a 2.5" lift with 305 M/T's running stock gears.....
I like using it, but dont want to preemptively wear something out just to daily drive with the PWR engaged.
Also, maybe this is a psychological brain misfire on my part but it seems like when I engage my PWR button the truck has a little more low end power....I assumed it only held the rpm's higher....am I crazy, loosing my mind or does it really do something other than hold the rpm's?
Facts, Thoughts, & Opinions?
I leave mine on all the time and I haven't had any problems. I kept track of MPG for one month with and one month without, figuring that was a pretty decent sampling of my typical driving. No difference whatsoever. I'm sure the higher RPMs get slightly worse mileage, but it is probably offset by the constant downshifting I seemed to be doing on my normal commute without the power button on.
I usually just leave mine on. It only changes the shift points, doesn't do anything to the engine (power). I don't think it will have any effect at all on longevity of the tranny, the only downside is slightly worse MPG.
So is there any real advantage to leaving it on?
Shift points are raised, giving you more "power" by letting the engine RPMs increase before shifting, basically makes you go a little quicker. Also it might hunt gears a little less.
Thanks for the responses....I was reading cruiserdan's "cost of ownership" memo/mission statement (it was a Jerry Maguire moment...lol) thinking of the power button.....I just didnt want to hurt my tranny....
Also whats the 2nd Start button for? I have never pushed it....
Allows you to start in 2nd. Handy on the trail when you have a slightly smooth section and want to go faster...put selector in 2, hit 2nd button, enjoy second gear without harsh up or downshifts.
(this is what I use it for).
FWIW, I leave the PWR button on all the time, it helps to have the shift points slightly higher, I've never experienced any difference "off the line" as you made a mention of, I think that is pure placebo effect cause the engine is still rolling through the same revs at that point whether the switch is on or off. HTH :cheers:
2nd start is also good for very slippery conditions when the reduction in off the line torque is a good thing.
I have noticed that when flooring the accelerator with or with out the power button engaged, the transmission shifts at redline. i.e. no difference in shift points under this particular condition. Have you observed this too?
I am running 35's on the stock 4.10's at 7,400 ft. elevation, and it is a different truck with PWR on. In "normal" mode the transmission will sit in overdrive and just bog down. Every now and again one of my kids or just some piece of shifting gear will turn PWR off and I'd might as well get out and run because it would be faster. My rig downshifts quickly and at the right time on uphills with PWR on...it is a very different response.
So...PWR never goes off (intentionally) until I eventually put in the 5.29's. I personally think the 2nd gear start is a relic of the age of really crappy tires.
I use second start when the terrain does not necessitate a true 1st granny gear and I don't want the shift to snap my neck a hundred times. Smoother when you aren't climbing but are staying in 4lo.
Here's a question I have not seen answered:
Why does the PWR button disengage when you hit the 2nd button and vice versa? I can't run both at the same time.
TR
I leave the PWR button on at all times except when TC is in low. It makes driving with stock gears and 33's at 7200' work pretty well. Without PWR, the transmission doesn't downshift soon enough, causing major loss of speed up hills and inability to pass without WOT.
I've noticed no significant change in mileage (I track it every tank).
I use 2nd Start almost all the time when TC is in low. I really dislike the abrupt shift from 1st to 2nd when in low. I shift the transmission into 1st manually when necessary.
I just got my 97 LX450 from a small dealership & was told that everythin gis working. I failed to test those 2 buttons 'PWR" & "2nd". I tried today & isn't there suppose to be a light that comes on the dash. I hope it's just a bulb. How can I test this now?. Would the rpm changes if I switch the PWR on? I'm new to the forum so excuse my ignorance.
So I tried the PWR button "ON" all day today and you guys were correct and I LOVED it......I mean it didnt turn my LX into a Porsche 911 but it SURE made a difference in the way the truck operated throughout the day.
The only thing that annoyed me was the green PWR light being on in the instrument cluster.....it made me keep thinking the CEL was on....I hate lights on in the cluster....lol
I also experience the similar. I got a 99 cruiser recently. First, after pushing down the PWR button no symbol in the instrument panel is on at all. And secondly, pushing the 2nd start button does cancels the power botton, but it does not stay there -- the 2nd Start symbol is not on either. Actually looking under direct sun light I did not find such symbols at all (other symbols even not illuminated are obvious to see under sunlight). So where should the PWR and 2nd Start symbols be?
Thanks!
TR
This is by design. As mentioned, PWR allows tranny to shift at higher rpm. If you are stopped, in PWR and hit 2nd, tranny will start in 2nd and shift normal. If depressed while driving, that will happen once tranny comes in 2nd.
If in 2nd, PWR is needed because you dont want power starting off in 2nd.
Hope that helped....
Russ
