Power Button
The 2nd button is very useful in some situations. My daughter, who drives a 100 called me last week and said she was stuck. There were about 6" of new wet snow and she was trying to turn around in a steep driveway. She said somthing like " shouldn't this cruiser be able to handle a little snow??? I wasn't sure if the 100 series had a 2nd button like the 80's do and told her to look for one. She found it and got out fine once it was engaged. She had no idea what it was for- saved me a trip over to strap her out.
I never daily drive with the PWR button engaged, I typically only use it when I need the extra kick in the pants (rpm's) to change lanes, get into traffic and so on....
When I need to change lanes or going up an incline, I just switch off the O/D for more punch. Would leaving the Power Button engaged help in these cases?
Of all people your a member of the club that really doesn't need to do this.;)
However it figures............:lol:
The more the merrier, my friend! :D :flipoff2: :D
No I don't but when I do that's what the AWD is for :D
And the 2nd button will help when you take off from a stop to not slip at first torque.
And have you seen the ad with that line in it? It is a good read.
#1: I know what you mean, I am just so involved in my driving that 2nd start or not, that I think it takes alot to get an AWD (Auto, 212h.p, 5-6k lb.) to spin. :confused: I think if people would realy consentate on there driving...................
#2: Toyota truck and LandCruiser owner's bible; by Moses Ludel
is where I saw it.
This was my thinking as well.
Wouldn't fewer shifts save wear on the transmission ?
Theoretically.
I think the real tangible advantage is less chance of overheating the tranny (when under load/towing/etc), when in "power" mode.
I do not have that second button... I don't think. Since I have been under the hood more than behind the wheel since I bought it, I may have over looked it. :grinpimp:
The 2nd button is very useful on the trail in low gear. It allows you to drive in second when the trail does not need 1st gear. If you let it shift on its own, you have to rev up the engine quite a bit to get it to shift to 2nd gear, and it does it with a big jolt.
On the trail now I immediately press the 2nd button and move the shifter to 1st or 2nd depending on trail condition. Very useful. In high gear I don't see the use for it.
Useful for extremely slick conditions (snow/ice, sand, etc). I've only used it maybe a couple of times.
Same reasoning behind when you want to use it on the trail, you don't want that big jolt which will cause your tires to slip.
I use mine (2nd start) quite extensively in the deep snow in low range. Also works good in the mud too.
I've seen some posts of using the 2nd Start Button and then shifting the lever into 1 or 2. Doesnt this negate the funtion of the button? My understanding is whether in High or Low range the 2nd Start button works the same way and:
When in 'D', the tranny starts in 2nd gear and works up from there so you dont spin the tires as easy and avoid a jolting shift when in Low Range.
When in '2', the tranny also starts in 2nd gear and stays there (until any safety high RPM governor takes over to save the engine, if any)...not sure the button does anything here
When in '1', the tranny starts in 1st gear and basically over-rode the 2nd start button and stays there (until any safety high RPM governor takes over, if any)
Am I missing something? :bang:
I think you got it. Manually shifting into 1 or 2 is nice on the downhills.
I am thinking a 93 does not have this 2nd start button
